My hass.io homeassistant build has failed to start after a restart. I’m hoping someone might be able to explain how to start it again from the underlying resinos environment.
Just now, I was running the OZW control panel (using the ozwcp hass.io add-on), which meant that homeassistant was stopped. Then I did a hassio ho reboot
(because ozwcp was playing up) and now homeassistant won’t start. I’ve tried a few cold / warm reboots, and it won’t come up.
The web server hasn’t started, nor has the SSH add-on. So I can’t access the web-front end or the SSH server. I can get into the underlying resin OS, though, with an ssh -p 22222 [email protected]
I’ve got plenty of room on the SD card. The resin-supervisor container starts fine and suggests that all is well:
root@hassio:/resin-data# docker logs resin_supervisor
19-02-03 22:24:47 INFO (MainThread) [__main__] Run Hass.io
19-02-03 22:24:47 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-02-03 22:24:47 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-02-03 22:24:47 INFO (MainThread) [hassio.addons] Startup initialize run 1 add-ons
19-02-03 22:24:48 WARNING (MainThread) [hassio.addons.addon] core_bluetooth_bcm43xx already running!
19-02-03 22:24:53 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-02-03 22:24:53 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-02-03 22:24:53 INFO (MainThread) [hassio.core] Hass.io is up and running
But there are very few containers running:
root@hassio:/resin-data# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
276f98094acf homeassistant/armhf-addon-bluetooth_bcm43xx "/run.sh" About an hour ago Up About an hour addon_core_bluetooth_bcm43xx
891be06758bb homeassistant/armhf-hassio-supervisor "python3 -m hassio" 2 weeks ago Up 35 minutes resin_supervisor
Not only that, there don’t seem to be many docker containers at all (started or stopped) - home assistant and core ssh seem to be missing (among others):
root@hassio:/resin-data# docker ps -a
9ce4b7353ce0 27e642c6/armhf-addon-nodered "/usr/bin/entry.sh..." About an hour ago Exited (1) About an hour ago addon_27e642c6_nodered
891be06758bb homeassistant/armhf-hassio-supervisor "python3 -m hassio" 2 weeks ago Up 36 minutes resin_supervisor
4ca1cfd4e405 homeassistant/armhf-addon-check_config "/run.sh" 3 months ago Exited (0) 3 months ago addon_core_check_config
ffe4f74bd3c9 homeassistant/armhf-addon-configurator "/run.sh" 6 months ago Exited (255) 6 months ago 0.0.0.0:3218->3218/tcp addon_core_configurator
49e1f962b2e4 homeassistant/resinos-hassio:1.3-raspberrypi3 "/bin/bash" 10 months ago Exited (0) 35 minutes ago resinos
I could assume the worst: for some reason my build is burnt, but it doesn’t seem likely. What seems much more likely is that the resin-supervisor has restored the state that I was in before the first reboot, which is to say home-assistant stopped.
Is there some way I can start it again? Which container does the hassio cli run from? This doesn’t work:
root@hassio:/resin-data# docker exec -it resin_supervisor bash
bash-4.4# hassio
bash: hassio: command not found
Any help would be greatly appreciated!
