I migrated Homeassistant and Zigbee2Mqtt from Docker to HA OS through a backup and restore.
I can operate all of my Zigbee devices without errors in the Zigbee2Mqtt addon (version: 1.39.0-1) and the Mosquitto broker (version: 6.4.1).
However, I do not get the system operating from Homeassistant. All of the lamps switched stay greyed out.
I am using this zigbee2mqtt configuration.yaml file:
mqtt:
server: mqtt://core-mosquitto:1883
user: MQTT-user
password: [****]
serial:
port: /dev/ttyACM0
advanced:
rtscts: false
pan_id: 6755
ext_pan_id:
- 221
- 221
- 221
- 221
- 221
- 222
- 221
- 221
channel: 11
network_key:
- 220
- 123
- 244
- 164
- 234
- 17
- 254
- 148
- 102
- 176
- 232
- 170
- 123
- 17
- 18
- 19
availability_timeout: 30
log_level: info
devices:
'0x14b457fffe71b542':
friendly_name: test_lamp
The addon shows this configuration:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
user: MQTT-user
password: [****]
serial:
port: /dev/ttyACM0
frontend: true
advanced:
pan_id: 6755
Btw, the device (in this case ‘test_lamp’) has this message in HA:
This entity is no longer being provided by the mqtt integration. If the entity is no longer in use, delete it in settings.
What am I missing?
Thanks for helping me out…
