'HomeAssistantCore.update' blocked from execution, system is not healthy
Helping a friend
battling with this error also, trying to install newest 2023.3.5 update,… or make tat actually trying to get the Cloudflare tunnel installed but being blocked by the system health.
don’t have portioner installed.
can’t install a ssh tool to get to terminal
have restarted platform multiple times now.
settings/system/repair => unignore
it’s saying something was ignore in 2023.3.4
HA is running on a Pi, headless, no KB.
G
Fixed… nothing like following Microsoft fixing principles… hard restart everything…
G
Having the same Problem, I think your best bet is to just wipe it! start with a fresh install. All the fixes I’ve found did not work so it has stayed broken for mouths now.
HA is running on intel noke, headless.
Do that command every night with crontab
Haha nice workaround. I wish it wasn’t needed, but this works for now. Portainer is super handy. I wasn’t able to use my Nvidia GPU with Frigate when it was running as the HASS addon, so I had to run it on the server with docker-compose. Portainer makes it so easy to create a new stack and paste in the config. But I guess I can see how it causes a lot of problems for the devs.
For information, I solved with the portable version of windows:
then I launch it with a .BAT/.CMD that contains:
@START /min portainer.exe --data=c:\portainer
@“C:\Program Files\Google\Chrome\Application\chrome.exe” --app=http://localhost:9000/
to be adjusted according to your browser.
Dears,
I think I have the same issue. My Home Assistant Supervised running on docker on a Raspberry Pi 4 and having a Portioner stops unexpectedly, at least once per day.
Do you have an idea what would be the best solution?
2024-03-08 01:04:39.853 WARNING (MainThread) [homeassistant.components.sonos.speaker] No recent activity and cannot reach Kitchen, marking unavailable
2024-03-08 01:04:39.856 WARNING (MainThread) [homeassistant.components.sonos.speaker] No recent activity and cannot reach Living Room, marking unavailable
s6-rc: info: service legacy-services: stopping
2024-03-08 01:25:11.039 ERROR (Thread-4) [pychromecast.socket_client] [Dining room display(192.168.1.22):8009] Failed to connect. No retries.
2024-03-08 01:25:11.464 WARNING (MainThread) [homeassistant.core] Task <Task pending name='Task-172742' coro=<EntityPlatform._update_entity_states() running at /usr/src/homeassistant/homeassistant/helpers/entity_platform.py:1002> wait_for=<Future pending cb=[BaseSelectorEventLoop._sock_write_done(28, handle=<Handle BaseS....155', 8002))>)(), Task.task_wakeup()]> cb=[set.remove()]> was still running after final writes shutdown stage; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdown
2024-03-08 01:25:11.470 WARNING (MainThread) [homeassistant.core] Task <Task pending name='Task-1685' coro=<MiniServer.start_loxone() running at /config/custom_components/loxone/miniserver.py:166> wait_for=<Future pending cb=[Task.task_wakeup()]> cb=[set.remove()]> was still running after final writes shutdown stage; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdown
[00:25:14] INFO: Home Assistant Core finish process exit code 0
[00:25:14] INFO: Home Assistant Core service shutdown
24-03-08 01:24:15 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-03-08 01:24:15 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-03-08 01:24:15 ERROR (MainThread) [supervisor.resolution.evaluations.container] Found image in unhealthy image list 'portainer/portainer' on the host
24-03-08 01:24:15 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-03-08 01:24:15 CRITICAL (MainThread) [supervisor.jobs] The following job conditions are ignored and will make the system unstable when they occur: {<JobCondition.HEALTHY: 'healthy'>}
24-03-08 01:24:15 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-03-08 01:24:15 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-03-08 01:24:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
24-03-08 01:24:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
24-03-08 01:24:15 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
24-03-08 01:24:17 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 0 new - 0 remove
24-03-08 01:25:03 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
24-03-08 01:25:03 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
24-03-08 01:25:03 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
I am still struggling with this conflict between Portioner and Home Assistant Supervised. I tried the nightly execution of “ha jobs options --ignore-conditions healthy” but at 1h20 something is the supervised container is stopping.
Any other suggestion Thanks!
I was just too fed up with poor performance/speed and issues, so i switched from supervised on a pi 4 to a 2011 laptop through a VM. Bridging in qemu/kvm and linux was a bit annoying to set up, but now its as if it runs HAOS and has 0 issues. Bluetooth passthrough was also very easy - the internsl Bluetooth chip was connected over a usb bus.
Thanks !
I still think I can make it work :slight_smile:
I stopped the portioner docker and surprisingly , I am running the “ha jobs options --ignore-conditions healthy” regularly and surprisingly it still complained about portioner
ONTAINER ID   IMAGE                                                           COMMAND                  CREATED        STATUS                      PORTS                                                 NAMES
a2c9bfe47704   portainer/portainer                                             "/portainer -H unix:…"   31 hours ago   Exited (2) 31 hours ago
d416a1cb70bd   ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.3.0   "/init"                  11 days ago    Exited (137) 17 hours ago
24-03-17 11:38:43 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-03-17 11:38:43 INFO (MainThread) [supervisor.host.services] Updating service information
24-03-17 11:38:43 INFO (MainThread) [supervisor.host.network] Updating local network information
24-03-17 11:38:43 ERROR (MainThread) [supervisor.resolution.evaluations.container] Found image in unhealthy image list 'portainer/portainer' on the host
24-03-17 11:38:43 WARNING (MainThread) [supervisor.resolution.evaluations.base] Found unsupported images: {'eclipse-mosquitto', 'portainer/portainer', 'teslamate/grafana', 'teslamate/teslamate', 'postgres'} (more-info: https://www.home-assistant.io/more-info/unsupported/software)
24-03-17 11:38:44 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-03-17 11:38:44 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-03-17 11:38:44 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-03-17 11:38:44 CRITICAL (MainThread) [supervisor.jobs] The following job conditions are ignored and will make the system unstable when they occur: {<JobCondition.HEALTHY: 'healthy'>}
24-03-17 11:38:44 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-03-17 11:38:44 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-03-17 11:42:06 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-03-17 11:42:07 ERROR (MainThread) [supervisor.resolution.evaluations.container] Found image in unhealthy image list 'portainer/portainer' on the host
24-03-17 11:42:07 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-03-17 11:42:36 CRITICAL (MainThread) [supervisor.jobs] The following job conditions are ignored and will make the system unstable when they occur: {<JobCondition.HEALTHY: 'healthy'>}
24-03-17 11:42:37 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, supervisor needs to be updated first
24-03-17 11:42:42 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
24-03-17 11:42:42 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
24-03-17 11:42:43 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.03.0
24-03-17 11:42:43 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2024.03.0.
24-03-17 11:43:14 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
24-03-17 11:43:14 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
24-03-17 11:43:14 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
24-03-17 11:43:14 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
24-03-17 11:43:14 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
24-03-17 11:43:14 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
24-03-17 11:43:14 INFO (MainThread) [supervisor.core] Supervisor is down - 0
24-03-17 11:43:14 INFO (MainThread) [__main__] Closing Supervisor
