Hello. Cannot get sensor data values in homeassistant. Tried everything cannot make it working.
I am running dockerized homeassistant, mosquito mqqt broker and mqqt gateway on the same RPI.
Temperature and humidity are being published correctly:
Homeassistant is connect to mqqt as i Can control and get values of my sonoof basic switch with no problems.
File permissions:
pi@raspberrypi:/opt/homeassistant $ ls -l
total 2044
-rw-r–r-- 1 root root 2 Jan 2 21:27 automations.yaml
-rw-r–r-- 1 root root 3062 Jan 27 09:43 configuration.yaml
-rw-r–r-- 1 root root 1794 Jan 2 21:47 configuration.yaml.save
-rw-r–r-- 1 root root 2090 Jan 20 14:47 configuration.yaml.save.1
-rw-r–r-- 1 root root 2430 Jan 20 14:47 configuration.yaml.save.2
-rw-r–r-- 1 root root 0 Jan 2 21:27 customize.yaml
drwxr-xr-x 2 root root 4096 Jan 2 21:27 deps
-rw-r–r-- 1 root root 0 Jan 2 21:27 groups.yaml
-rw-r–r-- 1 root root 7987 Jan 27 09:52 home-assistant.log
-rw-r–r-- 1 root root 2043904 Jan 27 09:44 home-assistant_v2.db
-rw-r–r-- 1 root root 359 Jan 27 09:34 mysensors1.pickle
-rw-r–r-- 1 root pi 0 Jan 27 08:59 mysensors4.json
-rw-r–r-- 1 root root 0 Jan 2 21:27 scripts.yaml
-rw-r–r-- 1 root root 157 Jan 2 21:27 secrets.yaml
drwxr-xr-x 2 root root 4096 Jan 2 21:27 tts
Homeassistant log:
2019-01-27 09:43:29 WARNING (SyncWorker_1) [mysensors.persistence] File does not exist or is not readable: /opt/homeassistant/mysensors1.pickle
2019-01-27 09:43:29 WARNING (SyncWorker_1) [mysensors.persistence] Trying backup file: /opt/homeassistant/mysensors1.pickle.bak
2019-01-27 09:43:29 WARNING (SyncWorker_1) [mysensors.persistence] File does not exist or is not readable: /opt/homeassistant/mysensors1.pickle.bak
2019-01-27 09:43:29 WARNING (SyncWorker_1) [mysensors.persistence] Failed to load sensors from file: /opt/homeassistant/mysensors1.pickle
2019-01-27 09:43:29 ERROR (SyncWorker_4) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:43:29 INFO (MainThread) [mysensors.gateway_mqtt] Setting up initial MQTT topic subscription
2019-01-27 09:43:29 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mygateway1-out/+/+/0/+/+, qos: 0
2019-01-27 09:43:29 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mygateway1-out/+/+/3/+/+, qos: 0
2019-01-27 09:43:39 ERROR (SyncWorker_5) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:43:49 ERROR (SyncWorker_11) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:43:59 ERROR (SyncWorker_6) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:44:09 ERROR (SyncWorker_13) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:44:19 ERROR (SyncWorker_1) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:44:29 ERROR (SyncWorker_3) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:44:39 ERROR (SyncWorker_15) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
2019-01-27 09:44:49 ERROR (SyncWorker_8) [mysensors.persistence] Permission denied when writing to /opt/homeassistant/mysensors1.pickle
Configuration.yaml
mqtt:
broker: 192.168.1.225
port: 1883
client_id: home-assistant-1
# discovery: true
logger:
default: error
logs:
mysensors: debug
homeassistant.components.mysensors: debug
mysensors:
gateways:
- device: mqtt
persistence_file: '/opt/homeassistant/mysensors1.pickle'
topic_in_prefix: 'mygateway1-out'
topic_out_prefix: 'mygateway1-in'
optimistic: false
persistence: true
retain: true
version: '2.1'
- platform: mqtt
state_topic: "mygateway1-out/1/0/1/0/0"
unit_of_measurement: '°C'
value_template: "{{ value_json.temperature }}"
- platform: mqtt
state_topic: "mygateway1-out/1/1/1/0/1"
unit_of_measurement: '%'
value_template: "{{ value_json.humidity }}"
Any ideas where the problem could be?
