I have tried installing the homebridge addon and it fails…
I am running hass.io on a Ubuntu svr 16.04 VM.
here is the log, any help appreciated.
17-10-11 23:09:50 INFO (MainThread) [hassio.addons] Startup application run 0 addons
17-10-11 23:09:50 INFO (MainThread) [hassio.addons] Load addons: 17 all - 0 new - 0 remove
17-10-11 23:24:27 INFO (SyncWorker_2) [hassio.dock.addon] Start build d89827df/amd64-addon-homebridge:1.0.3
17-10-11 23:24:28 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 422, in start
resp = yield from self._request_handler(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web.py”, line 306, in _handle
resp = yield from handler(request)
File “/usr/lib/python3.6/site-packages/hassio/api/util.py”, line 31, in wrap_api
answer = await method(api, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/hassio/addons/addon.py”, line 466, in install
if not await self.docker.install(self.last_version):
File “/usr/lib/python3.6/site-packages/hassio/dock/util.py”, line 18, in wrap_api
return await method(api, *args, **kwargs)
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/hassio/dock/addon.py”, line 198, in _install
return self._build(tag)
File “/usr/lib/python3.6/site-packages/hassio/dock/addon.py”, line 211, in _build
image = self.docker.images.build(**build_env.get_docker_args(tag))
File “/usr/lib/python3.6/site-packages/docker/models/images.py”, line 175, in build
raise BuildError(chunk[‘error’])
docker.errors.BuildError: invalid reference format: repository name must be lowercase
17-10-11 23:30:25 INFO (SyncWorker_1) [hassio.dock.addon] Start build d89827df/amd64-addon-homebridge:1.0.3
17-10-11 23:30:25 ERROR (MainThread) [aiohttp.server] Error handling request
