Homebridge Alarm Control
Hi All,
I have successfully setup a manual alarm_control_panel in HA and I can see it in the Apple Home app.
My question is, how do you control the alarm with Siri? Does anyone know the command?
Cheers.
Hello @Kanishkaz! How are you?
I’ve managed to insert a Manual Alarm Control Panel on my configuration.yaml but Homebridge does not detect it.
Could you please tell me how you did it?
Thanks!
You need to make sure you have the alarm_control_panel listed as a supported type in the homebridge config.json.
"platforms": [
       "platform": "HomeAssistant",
       "name": "HomeAssistant",
       "host": "https://127.0.0.1:8123",
       "password": "XXXXX,
       "supported_types": ["alarm_control_panel", "automation",  "binary_sensor"],
       "logging": true,
       "verify_ssl": false
That’s it.
Awesome! I did not have “alarm_control_panel” on my config file! Thanks a lot! Have a great day!
Sorry to dig up an old thread, but I have a similar question as the OP.
I have successfully added my HA alarm into homebridge and it is showing up in Homekit, but when I try to use Siri to enable/disable the alarm, she says: “Sorry, I can’t control your home security system. Visit the Home app for this information.”
Any ideas? Or has apple simply blocked the ability to do this?
The only way I was able to set my alarm panel with Siri was to set up a scene with whatever state I wanted my security panel to be in. Such as Home: state off and Away: armed. Hope this helps.
for alarm_control_panel in homebridge
arm (home, away, night) alarm name.
disarm alarm name.
