I’ve had this addon working in the past, after wiping my Hassio had to re-setup but now have the issue that despite successfully adding the home-assistant bridge in the iOS Home app, however none of my HA devices are showing up. I see in the homebridge logs:
[2018-2-5 07:27:58] Loaded plugin: homebridge-homeassistant
[2018-2-5 07:27:58] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2018-2-5 07:27:58] ---
[2018-2-5 07:27:58] Loaded config.json with 0 accessories and 1 platforms.
[2018-2-5 07:27:58] Loading 1 platforms...
[2018-2-5 07:27:58] [HomeAssistant] Initializing HomeAssistant platform...
[2018-2-5 07:27:58] [HomeAssistant] Fetching HomeAssistant devices.
[2018-2-5 07:27:58] Loading 0 accessories...
undefined:1
502: Bad Gateway
And my Homebridge config.json
"bridge": {
"name": "Home Assistant",
"username": "02:23:45:67:89:AB",
"port": 51826,
"pin": "645-57-122"
"description": "Homebridge for Home Assistant",
"accessories": [],
"platforms": [
"platform": "HomeAssistant",
"name": "HomeAssistant",
"host": "http://hassio/homeassistant",
"password": "",
"default_visibility": "hidden",
"supported_types": [
"automation",
"binary_sensor",
"climate",
"cover",
"device_tracker",
"fan",
"group",
"input_boolean",
"light",
"lock",
"media_player",
"remote",
"scene",
"script",
"sensor",
"switch",
"vacuum"
"logging": true,
"verify_ssl": true
Any advice?
Cheers
