finally I switched from FHEM to home assistant and I am looking forward to installing heating and lighting control in this more modern system. Max! radiators and window contacts communicate with a CUL-stick, which makes homegear necessary.
The first devices are already integrated in Homegear, but the interface between Homegear and HASS does not work. Constantly the following error message appears when starting the system:
Logger: pyhomematic._hm
Source: /usr/local/lib/python3.8/site-packages/pyhomematic/_hm.py:693
First occurred: 18:53:25 (1 occurrences)
Last logged: 18:53:25
Failed to initialize proxy for homeassistant-wireless
At this point I already tried different settings like json, xml and metadata, with and without username/password, but the error message is always the same.
I am very happy about hints and tips to be able to get started with HASS.
Thank you very much for your prompt answer. I tried your Python3 script in both the Homegear and HASS containers. In both cases, a list of all kinds of devices was printed, including the already bound MAX! devices…
Since you have mentioned Containers, have a look at the local_ip and local_port options. When using those, you probably also have to set the callback_ip and callback_port. Additionally, if there is a firewall in place, you have to allow connections accordingly.
