Hi, I have this domain / entity count list:
alarm_control_panel: 1
automation: 46
binary_sensor: 26
button: 75
camera: 6
device_tracker: 65
image: 5
input_boolean: 6
input_select: 2
light: 22
lock: 1
media_player: 6
number: 35
person: 1
remote: 3
scene: 16
script: 6
select: 61
sensor: 185
sun: 1
switch: 133
tts: 2
update: 18
weather: 2
zone: 1
I’m trying to keep them in bounds by using filters:
homekit:
filter:
exclude_domains:
- automation
- script
- scene
- lock
- remote
- device_tracker
- binary_sensor
- sensor
- select
exclude_entity_globs:
- automation.*
- script.*
- scene.*
- lock.*
- remote.*
- device_tracker.*
- binary_sensor.*
- sensor.*
- select.*
include_entities:
- device_tracker.iphone
- device_tracker.ipad_von_michael
However, I keep getting these messages:
2023-09-13 00:01:01.955 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.homekit_trigger_zuhause_verlassen_scene as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.957 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.homekit_trigger_zuhause_ankommen_scene as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.958 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.wohnzimmer_deckenlicht_toggle_lichtschalter_2 as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.958 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.galerie_lichtschalter as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.959 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.homekit_trigger_movie_night_scene as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.959 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.kuche_bewegungssensor_led_ein as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.960 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.kuche_bewegungssensor_led_aus as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.960 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.haustur_klingel as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.961 WARNING (MainThread) [homeassistant.components.homekit] Cannot add automation.nacht2a as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.961 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_externe_ipv6 as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.961 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_upload_durchsatz as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.961 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_download_durchsatz as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.962 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_gb_gesendet as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.962 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_gb_empfangen as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.962 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_link_upload_durchsatz as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.962 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_link_download_durchsatz as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.963 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_rauschabstand_zum_link_upload as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.963 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_rauschabstand_zum_link_download as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.963 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_link_upload_leistungsdampfung as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.963 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_link_download_leistungsdampfung as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.964 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.fritz_box_7490_externe_ip as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.964 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.haustur_battery as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.964 WARNING (MainThread) [homeassistant.components.homekit] Cannot add lock.haustur_lock as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.964 WARNING (MainThread) [homeassistant.components.homekit] Cannot add binary_sensor.haustur_ding as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.964 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.haustur_info as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.965 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.haustur_wireless as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.987 WARNING (MainThread) [homeassistant.components.homekit] Cannot add binary_sensor.octoprint_printing as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.988 WARNING (MainThread) [homeassistant.components.homekit] Cannot add binary_sensor.octoprint_printing_error as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.989 WARNING (MainThread) [homeassistant.components.homekit] Cannot add button.octoprint_resume_job as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.989 WARNING (MainThread) [homeassistant.components.homekit] Cannot add button.octoprint_pause_job as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.990 WARNING (MainThread) [homeassistant.components.homekit] Cannot add button.octoprint_stop_job as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.991 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_actual_bed_temp as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.992 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_target_bed_temp as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.993 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_actual_tool0_temp as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.994 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_target_tool0_temp as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.994 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_current_state as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.995 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_job_percentage as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:01.996 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_estimated_finish_time as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:02.012 WARNING (MainThread) [homeassistant.components.homekit] Cannot add sensor.octoprint_start_time as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:02.056 WARNING (MainThread) [homeassistant.components.homekit] Cannot add camera.octoprint_camera as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:02.059 WARNING (MainThread) [homeassistant.components.homekit] Cannot add script.1693609641839 as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:02.060 WARNING (MainThread) [homeassistant.components.homekit] Cannot add script.news_say as this would exceed the 150 device limit. Consider using the filter option
2023-09-13 00:01:02.094 WARNING (MainThread) [homeassistant.components.homekit] The bridge Home Assistant Bridge has entity camera.192_168_2_163. For best performance, and to prevent unexpected unavailability, create and pair a separate HomeKit instance in accessory mode for this entity
2023-09-13 00:01:02.098 WARNING (MainThread) [homeassistant.components.homekit] The bridge Home Assistant Bridge has entity camera.kamera_flur. For best performance, and to prevent unexpected unavailability, create and pair a separate HomeKit instance in accessory mode for this entity
2023-09-13 00:01:02.133 WARNING (MainThread) [homeassistant.components.homekit] The bridge Home Assistant Bridge has entity camera.woox_smart_camera. For best performance, and to prevent unexpected unavailability, create and pair a separate HomeKit instance in accessory mode for this entity
2023-09-13 00:01:02.141 WARNING (MainThread) [homeassistant.components.homekit] The bridge Home Assistant Bridge has entity camera.kamera_wohnzimmer. For best performance, and to prevent unexpected unavailability, create and pair a separate HomeKit instance in accessory mode for this entity
2023-09-13 00:01:02.160 WARNING (MainThread) [homeassistant.components.homekit] The bridge Home Assistant Bridge has entity camera.kamera_galerie. For best performance, and to prevent unexpected unavailability, create and pair a separate HomeKit instance in accessory mode for this entity
2023-09-13 00:01:02.171 WARNING (MainThread) [homeassistant.components.homekit] The bridge Home Assistant Bridge has entity media_player.samsung_tv. For best performance, and to prevent unexpected unavailability, create and pair a separate HomeKit instance in accessory mode for this entity
2023-09-13 00:01:02.204 WARNING (MainThread) [homeassistant.components.homekit] The bridge Home Assistant Bridge has entity camera.octoprint_camera. For best performance, and to prevent unexpected unavailability, create and pair a separate HomeKit instance in accessory mode for this entity
Any cure for this?
Thank you in advance for any advice
