Homekit and several users
Configuring homekit was easy. The problem is that i want to add my wife as well but seems two devices cannot be connected to the HA homekit instance?
Furthermore can’t use the apples built in share function. Just states sharing failed. Is this a limitation?
I can sucessfully share my home with my wife using the apple sharing feature. It includes home assistant together with my tradfri system.
I did not try to connect more than one user to homekit in home assistant, since the sharing feature works flawlessly for us.
Hmm. Wonder than why it fails in my case. Tried first from mine and failed. The circle sending just stayed there forever. Deleted the .homekit file paired with wifes ipad and failed as well with an error
All good here. My home is shared with 5 people.
How you fix it’s here the same problem?
