Homekit Bridge_Camera captures image every 10s in Home App Dashboard
Hello all,
I have a problem with Homekit Bridge integration with camera accessory.
The camera shows on the Home App dashboard (iphone device) but it is most likely not streaming, it is capturing image every 10s
After 10s it is changed to “now”, capture current stream, and counting from 1s, 2s up to 10s (the image is freezing during the counting), then repeat to “now”.
It can live stream without problem only when I click and open the camera. is it possible to have live stream on Home App dashboard without clicking it? IMO it is quite annoying to monitor CCTV but I need to open it one by one instead monitoring all the cameras on the dashboard view
My configuration is below
  • Home Assistant OS
  • Reolink Integrations → Only enable fluent stream entity (low res)
  • Reolink NVR (NVS8) → HTTP, RTSP, ONVIF enabled
  • Reolink CX410
On the HA, the camera is live stream without problem
That’s Apple HK video in a nutshell. Frequent snapshot updates (as, and if, it can) but user must select camera to display live stream.
It is my first time having a camera in Apple home app and never known the experience having a camera in it.
I thought it is an issue that could be resolved.
Many thanks for your information
