Hi, i’ve set up HomeKit Bridge integration in my configuration.yaml file as follows:
#homekit bridge
homekit:
- filter:
include_entities:
#- switch.charging_block
#- switch.desk_lamp
#- switch.hue_outlet
#- switch.left_lamp
#- switch.living_room_lamp
#- switch.plug_2
#- switch.plug_5
#- switch.outdoor_switch_00961185
- light.hue_top
- light.hue_middle
- light.hue_bottom
#- media_player.amru
#- remote.amru
#- media_player.denon_avr_s740h
#- media_player.living_room_tv
#- media_player.samsung_un46d6000
#- media_player.spotify_person
# - climate.downstairs_thermostat
#- climate.model_3_hvac_climate_system
#- scene.good_morning
#- scene.good_night
- name: HASS Bridge 3
- port: 56337
My goal here is to include ONLY the entities in include_entities. My understanding from the documentation is that if you only use include_entities, it should only include those entities.
However, you may see that I have many of my entities commented out. The reason for that is that when Home Assistant starts up, I get a notification that says:
Invalid config
The following integrations and platforms could not be set up:
homekit
Please check your config.
When I check my logs, I see that it appears to be an issue with duplicative entities:
2020-08-25 09:42:30 ERROR (MainThread) [homeassistant.config] Invalid config for [homekit]: contains duplicate items: [‘Home Assistant Bridge’] for dictionary value @ data[‘homekit’]. Got [OrderedDict([(‘filter’, OrderedDict([(‘include_entities’, [‘light.hue_top’, ‘light.hue_middle’, ‘light.hue_bottom’])]))]), OrderedDict([(‘name’, ‘HASS Bridge 3’)]), OrderedDict([(‘port’, 56337)])]. (See /config/configuration.yaml, line 52). Please check the docs at https://www.home-assistant.io/integrations/homekit
2020-08-25 09:42:30 ERROR (MainThread) [homeassistant.setup] Setup failed for homekit: Invalid config.
For the record, line 52 of my YAML is simply "homekit:, the beginning of my homekit configuration. I commented out all of my entities one-by-one until I was down to one, and yet I still get this error.
Can anyone offer any guidance?
