Hi! I am a blind person using home assistant. Every place I look, documentation, ETC, it just says to select what I want. The problem is that the boxes to select things show up as a text box, so I can only type in them, which wouldn’t be a problem if it worked like that, but that is where the problem is. I am unable to check anything to be exposed to homekit. I can edit the yaml under .storage/core.device.entry where the homekit config is, but when I re-enable it, I never get a code. If I do a completely manual configuration in configuration.yaml, it doesn’t load.
