Hello Every Body, I have a problem with the integration of aqara sensor in Home ios app.
Explication
I have in my HA aqara sensor (T° & humidity) and binary-sensor (window/door) connected to home assistant with conbee II (Zigbee gateway)
I have also sonoff tasmota, netatmo weather station, cpu temp (cli command) tado temp info In HA exported to Home ios application by homekit bridge.
If all sensor are correctly added in home app, I lost all zigbee sensor and binary sensor often. These sensore are visible in HA but disappear (no simply not reachable) in Home ios APP
The other sensor are always visible In home ios app. The only solution found is to delete the homekit.state and create a new integration of the home assistant bridge in Home ios app.
Can you help me please ?
