HomeKit Bridge Siri commands work but siri always replies back with "<device> is not responding"
I’m using HomeKit Bridge to connect to home assistant and almost works perfectly, the only problem I have is when I issue Siri commands it always tells me some of the devices are not responding but the commands actually work. For example, my garage door opener is a ratgdo. I can say “siri open the garage door” and it will respond, “opening the garage door” but then almost immediatly reply back “the garage door is not responding” and then the garage door succesfully opens followed by a homekit notification telling me the garage door is opened.
It’s more of an annoyance than anything else and I’ve lived with it for a LONG time, but I’d like to get it to work as expected.
Interestingly, my garage doors appear to be the only devices that behave this way. The Siri command “Siri, turn on the master bedroom fan” does not come back with “the master bedroom fan isn’t responding” like the garage door does.
I’ve searched the forum but can’t find the solution. Any help would be appreciated.
Thanks!
I’m having this same issue after it working fine for some time. Did you ever figure out what was causing the issue for you?
