I’m using HomeKit to control a WLED LED-Strip. The strip is connected to HomeAssistant via MQTT.
I can use HomeKit to control the brightness of the strip but the color seems always to be “delayed” by one color.
For example:
I set the color to red -> the strip does nothing
I set the color to green -> the strip becomes red
I set the color to blue -> the strip becomes green
So it’s always using the previously selected color.
It seems to work when I control the strip directly from the HomeAssistant frontend, so I think, it must be an issue with HomeKit or the connection between HomeKit and HomeAssistant.
Did anyone experience a similia behavior/know how to fix it?
Thank you!
I’m using the most recent version of HomeAssistant in a Docker container.
