Homekit Controller BLE connection failure
I’m trying to connect my eve plug to home assistant. The problem is the following.
python3 -m homekit.discover_ble
Name: Eve Energy 58D4
MAC: e7:61:56:1d:98:e1
Configuration number (cn): 2
Device ID (id): 5D:DD:67:99:3D:9E
Compatible Version (cv): 2
Global State Number (s#): 2
Status Flags (sf): The accessory has not been paired with any controllers. (Flag: 1)
Category Identifier (ci): Outlet (Id: 7)
python3 -m homekit.pair_ble -m “e7:61:56:1d:98:e1” -p “308-09-311” -f ./homekit_controller-entity-map -a “eve” --log debug
2019-06-29 23:45:50,463 pair_ble.py:0046 DEBUG Using adapter “hci0”.
2019-06-29 23:45:50,468 controller.py:0263 WARNING Loaded pairing for data with missing connection type. Assume this is IP based.
‘str’ object does not support item assignment
2019-06-29 23:45:50,469 pair_ble.py:0053 DEBUG ‘str’ object does not support item assignment
File “/srv/homeassistant3.7/lib/python3.7/site-packages/homekit/pair_ble.py”, line 50, in
controller.load_data(args.file)
File “/srv/homeassistant3.7/lib/python3.7/site-packages/homekit/controller/controller.py”, line 261, in load_data
data[pairing_id][‘Connection’] = ‘IP’
TypeError: ‘str’ object does not support item assignment
Can anybody please tell me, what I am doing wrong?
BLE is not currently supported for HomeKit controller. Good idea to try pairing outside of HA like this, it’s probably quite close to working, but those files are not in the same format.
