HomeKit Controller - Cannot add pairing as device can no longer be found
I just got a Hive system with bridge.
When I try to add it with through Configuration → Devices & Services → Add Integration → HomeKit Controller I get this popup:
When I click submit it fails with “Aborted” title popup saying “Cannot add pairing as device can no longer be found.”.
I have two other HomeKit Controller integrations working fine.
I also verified if I can connect to Hive Bridge directly from an iPhone and that worked fine (I also unpaired it from the phone as it stopped appearing in HomeKit Controller search while it was paired to the phone).
There are few questions I was hoping someone could help with:
  • How can I pair Hive Bridge?
  • Is there some way I can manually configure that integration?
  • Where do I see more detailed logs/how do I debug this situation?
