I’ve had a HomeKit Controller based integration working for quite some time (connected to a Polypipe Smarthub) and its been working flawlessly.
Recently it failed to connect with the following error:
2022-09-29 08:58:21.882 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Polypipe SmartHub' for homekit_controller integration not ready yet: Timeout while waiting for connection to device 169.254.8.217:4238; Retrying in background
That IP address is not the IP found in the configuration file and removing the configuration in core.config_entries: (pairing data removed for this post, but it is correct)
"entry_id": "68d13588bf24a3f3a0e801d539ebdd98",
"version": 1,
"domain": "homekit_controller",
"title": "Polypipe SmartHub",
"data": {
"AccessoryPairingID": "85:B1:51...",
"AccessoryLTPK": "83c42eb72cf60a6e324d...",
"iOSPairingId": "b783c4fc-c7ca-4e0e-...f",
"iOSDeviceLTSK": "9d3fa62d3b761b49f40afe6cb...",
"iOSDeviceLTPK": "40ba2bd7fc8eec8e6d2a01d6...",
"AccessoryIP": "192.168.1.216",
"AccessoryPort": 4238,
"Connection": "IP"
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "zeroconf",
"unique_id": "85:b1:51...",
"disabled_by": null
If I remove this entry, reboot the device, re-add the config and reboot the config works again for a period (a few hours maybe).
The Polypipe kit is up and working, pings fine and everything is up as far as I can tell. Not really sure what else to try? Any help would be much appreciated!
Edit:
Some information regarding my config:
Home Assistant 2022.9.7
Supervisor 2022.09.1
OS 9.0
Frontend 20220807.2-latest
Running on a Raspberry Pi
Regards, Daniel
