Hey!
I have a KooGeek LS1 light strip that only supports HomeKit but since version 0.68, there should be something called HomeKit controller to Home Assistant, which as I understand, makes it possible to get components from HomeKit to collaborate with HA.
If you follow the instructions, you should add the following to the config file:
discovery:
enable:
- homekit
The problem is that I get the following error message on the front page:
Invalid config
The following components and platforms could not be set up:
- homekit-controller
Please check your config.
and the log file shows the following:
I should add that I run Home Assistant 0.77.3 on a Mac mini and that I have installed libmpfr and libmpc via ‘brew install’ but now I’ve got stuck. I can not get rid of the error message or figure out what to do to move on and I hope that someone here can help me.
Andreas
