**Home Assistant release with the issue: 0.95.4
**Last working Home Assistant release (if known): none
**Operating environment (Hass.io/Docker/Windows/etc.): Rasperry pi3b
**Component/platform: Homebridge
Description of problem: Homekit controller only shows 1 accesory of 3
Problem-relevant configuration.yaml entries and (fill out even if it seems unimportant): Using Homekit accesry integration to discover 1 platform with 3 accesories under homebridge, its works ok in apple home
Traceback (if applicable):
**Additional information:I have running homebridge in a separate server. when i use in iphone home all the decives work well. when i try to put in homeassistant only shows 1 of the 3 devices. Always is the same, but only one.
