Yesterday, I decided to try to move away from Homebridge and go with the HomeKit component. Because it appears that Homebridge will not likely be supported in the near future. And while it was a challenge to get everything back up and going I finally figured out everything that I needed to do as this is very different and much harder to use then home bridge. But after some time my home app on my iOS device becomes unresponsive ton Home Assistant and added components. If I restart home Assistant everything loads back fine but after more times they all crash again. Has anybody else had issue similar to this?
