Homekit Infused 5 (HKI) v2023.1.3
Ofcourse, you need to use the 2.0 version of the ios App. It is currently in beta. I will not advise people to use beta versions though. However the app is pretty much production ready.
Hello again Jim!
Iā€™m a little bit confused about one thing and I hope to get some help from You!
I personalised for example a light in customize.yaml with a custom icon, but it doesnā€™t appear on frontend, only in state mode.
I attach some printscreens:
Could you send me the code of that specific button? Also the code of the button template that you use (if you use that ofc).
At the same time I also have a question for you. Where did you get that icon?
Jim, I use for the button your button template and the code inside the view is:
         - type: custom:decluttering-card
           template: button
           variables:
           - entity: light.candelabru
           - name: Candelabru
           - icon:
           - color: auto
           - size: 38%
           - grid:
              !include ../includes/light-devices-grid.yaml
For the icons I highly recommend https://www.flaticon.com/home
L.E: Jim, it is possible in your button template inside notification area to show the state?
looks very clean!
would you mind share the code for the button and the temperature?
Thanks .
Hello! Im glad that you like what Ive done with the help of this community!
For temperature and humidity I used mini-graph-card with a gradient, gradient that you can personalize on https://cssgradient.io/ . This is my code:
- type: custom:mini-graph-card
         style: |
          ha-card {
          background: rgb(255,70,70);
          background: linear-gradient(349deg, rgba(255,70,70,1) 24%, rgba(249,208,124,1) 100%);
          color: white;
          ha-icon {
          color: white;
         name_adaptive_color: true
         icon_adaptive_color: true
         align_icon: right
         entities:
         - sensor.veranda_airpurifier_temp
         hours_to_show: 24
         points_per_hour: 1
         animate: true
         hour24: true
         extrema: true
         line_width: 3
         font_size: 75
         line_color: '#fff'
         show:
          points: hover
          fill: fade
and for the buttons I used Jim`s template button.yaml
Thank you! can you share also the buttons ?
for the button I used decluterring-card with button template from Jim
Can you tell me what is the color of the button?
Just white? If not can you share the code of the color?
And also can you share the background you use?
Yes it should be possible to show the state in the notification area. ( you mean the badges in the right corner right?) you might need to adjust the template with the border radius though.
Also in your code, try removing this line:
- icon:
It might be your icon problem
Edit: it could also be the version of the template you are using. Are you using my latest template? Because the older templates have mdi hardcoded so default icons set in customize.yaml will not work with those. Only way to solve that is to either use my newer templates or remove the mdi from the code yourself.
Hi @jimz011,
First, I wanted to say thank you, I love the project and I use it a lot.
Second thing, I have problem with ā€œpopup-cardsā€ [Homekit Infused (HKI) v0.13.3].
After the last update it stopped appearing to me
02.frontpage.yaml
- title: Home
  path: home
# Popup cards are used for actionable notifications on the frontpage
  popup_cards:
    !include ../popup-cards/notification-popup.yaml
  cards:
# Weather Card and Quick Access Menu, These are
# Conditional and the conditions are set on the
# alarm. If you have a different alarm entity,
# use that instead.
    - type: vertical-stack
      cards:
        - type: conditional
          conditions:
            - entity: alarm_control_panel.home_alarm
              state: 'disarmed'
          card:
            !include ../includes/simple-weather-card.yaml
        - type: conditional
          conditions:
              state_not: 'disarmed'
          card:
            template: quick-access-menu
            variables:
              - name1: Security
              - icon1: mdi:cctv
              - path1: security
              - entity3: alarm_control_panel.home_alarm
              - name3: Alarm
              - icon3: mdi:shield-check
              - path3: alarm
              - hold_action:
                  action: call-service
                  service: input_boolean.toggle
                  service_data:
                    entity_id: input_boolean.simple_alarm
# Frontpage Picture Elements, For variables options please
# check the decluttering templates. These cards are conditional
# the conditions are set on a person being home or away. Use
# your own person entities here.
        # Left Photo (condition home)
        - type: horizontal-stack
          cards:
            - !include ../includes/blank-card.yaml
            - type: conditional
              conditions:
                - entity: person.talia
                  state_not: "home"
              card:
                template: person
                variables:
                  - person: person.talia
                  # - email: !secret taliasensor
                  - direction: left
                  - image: '/local/images/TaliaProfile1.png'
                  # - postnl: sensor.postnl_stephanie_packages
                  - travel_time: sensor.travel_time_talia
                  - battery: sensor.talias_iphone_battery_level
                  - icon: mdi:home
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/talia
        # Left Photo (condition not_home)
            - type: conditional
              conditions:
                  state: "home"
              card:
                template: person
                variables:
                  - direction: left
                  - travel_time: sensor.travel_time_talia_work
                  - icon: mdi:office-building
                  - tap_action:
                      action: navigate
        # Right Photo (condition home)
            - type: conditional
              conditions:
                - entity: person.dor
                  state_not: "home"
              card:
                template: person
                variables:
                  - person: person.dor
                  - email: sensor.email_dorko87
                  - direction: right
                  - image: '/local/images/DorProfile1.png'
                  # - postnl: sensor.postnl_jimmy_packages
                  - travel_time: sensor.travel_time_dor
                  - battery: sensor.dorkonviser_s_iphone_battery_level
                  - icon: mdi:home
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/dor
        # Right Photo (condition not_home)
            - type: conditional
              conditions:
                  state: "home"
              card:
                template: person
                variables:
                  - direction: right
                  - travel_time: sensor.travel_time_dor_work
                  - tap_action:
                      action: navigate
        # Middle Photo (This is the dog in my config)
        # - type: horizontal-stack
        #   cards:
        #     - !include ../includes/blank-card.yaml
        #     - type: picture-elements
        #       style: |
        #         ha-card {
        #           border-radius: {{ states('input_select.border_radius') }};
        #           box-shadow: {{ states('input_select.box_shadow') }};
        #           overflow: hidden;
        #       image: '/local/images/tala2.png'
        #       elements:
        #         - type: image
        #           entity: person.tala
        #           tap_action:
        #             action: navigate
        #             navigation_path: /lovelace/dog
        #           hold_action:
        #             action: navigate
        #           style:
        #             left: 50%
        #             top: 50%
        #             width: 100%
        #             heigth: 100%
        #         - type: state-label
        #           style:
        #             left: 0
        #             bottom: 0
        #             pointer-events: none
        #             font-size: 16px
        #             line-height: 24px
        #             color: white
        #             background-color: rgba(0, 0, 0, 0.3)
        #             width: 100%
        #             transform: initial
        #             padding: 0 8px
# Frontpage Shortcut Buttons, These are once again conditional
# If the alarm is set to anything but disarmed these buttons
# will hide and only the quick access menu will be accessible.
# Remember to change the alarm entity to match your own.
        # First Row
        - type: conditional
          conditions:
              state: 'disarmed'
          card:
            cards:
                template: button
                variables:
                  - name: Climate
                  - label: Control
                  - icon: mdi:air-conditioner
                  - show_state: false
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/climate
                      haptic: light
                  - hold_action:
                      action: more-info
                      haptic: light
                  - entity: input_boolean.notification_current_climate
                  - margin-right: 40px
                  - opacity: 0.8
                  - notification: "[[[ if (states['sensor.current_climate_on'].state > 0) return `${states['sensor.current_climate_on'].state}`; else return '&nbsp' ]]]"
                  - custom_fields:
                      notification:
                        - background-color: "[[[ if (states['sensor.current_climate_on'].state == 0) return 'var(--card-color-off)'; else return 'var(--label-color-off)'; ]]]"
                        - color: var(--notification-badge-color)
                        - border-radius: 50%
                        - overflow: visible
                        - position: absolute
                        - right: 7%
                        - top: 7%
                        - height: 22px
                        - width: 22px
                        - font-size: 11px
                        - line-height: 20px
              # Button 2
                template: button
                variables:
                  - name: Lights
                  - label: Control
                  - icon: mdi:floor-lamp
                  - show_state: false
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/lights
                      haptic: light
                  - hold_action:
                      action: more-info
                      haptic: light
                  - entity: input_boolean.notification_current_lights
                  - opacity: 0.8
                  - notification: "[[[ if (states['sensor.current_lights_on'].state > 0) return `${states['sensor.current_lights_on'].state}`; else return '&nbsp' ]]]"
                  - custom_fields:
                      notification:
                        - background-color: "[[[ if (states['sensor.current_lights_on'].state == 0) return 'var(--card-color-off)'; else return 'var(--label-color-off)'; ]]]"
                        - overflow: visible
                        - right: 7%
                        - top: 7%
                        - height: 22px
                        - width: 22px
                        - font-size: 11px
                        - line-height: 20px
              # Button 3
                template: button
                variables:
                  - name: Devices
                  - label: Control
                  - icon: mdi:power-plug
                  - show_state: false
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/devices
                      haptic: light
                  - hold_action:
                      action: more-info
                      haptic: light
                  - entity: input_boolean.notification_current_devices
                  - opacity: 0.8
                  - notification: "[[[ if (states['sensor.current_devices_on'].state > 0) return `${states['sensor.current_devices_on'].state}`; else return '&nbsp' ]]]"
                  - custom_fields:
                      notification:
                        - background-color: "[[[ if (states['sensor.current_devices_on'].state == 0) return 'var(--card-color-off)'; else return 'var(--label-color-off)'; ]]]"
                        - overflow: visible
                        - right: 7%
                        - top: 7%
                        - height: 22px
                        - width: 22px
                        - font-size: 11px
                        - line-height: 20px
              # Button 4
                template: button
                variables:
                  - name: Security
                  - label: Panel
                  - icon: mdi:cctv
                  - show_state: false
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/security
                      haptic: light
                  - hold_action:
                      action: more-info
                      haptic: light
                  - entity: input_boolean.notification_current_sensors
                  - opacity: 0.8
                  - notification: "[[[ if (states['sensor.current_sensors_on'].state > 0) return `${states['sensor.current_sensors_on'].state}`; else return '&nbsp' ]]]"
                  - custom_fields:
                      notification:
                        - background-color: "[[[ if (states['sensor.current_sensors_on'].state == 0) return 'var(--card-color-off)'; else return 'var(--label-color-off)'; ]]]"
                        - overflow: visible
                        - right: 7%
                        - top: 7%
                        - height: 22px
                        - width: 22px
                        - font-size: 11px
                        - line-height: 20px
        # Second Row
        - type: conditional
          conditions:
              state: 'disarmed'
          card:
            cards:
              - type: conditional
                conditions:
                  - entity: media_player.yamaha_receiver_salon
                    state: 'off'
                card:
                  template: button
                  variables:
                    - name: Cleaning
                    - label: Lists
                    - icon: mdi:broom
                    - show_state: false
                    - tap_action:
                        action: navigate
                        navigation_path: /lovelace/cleaning
                        haptic: light
                    - hold_action:
                        action: navigate
                        haptic: light
                    - entity: input_boolean.dummy1
                    - opacity: 0.8
              # Button 1 (condition receiver on)
              - type: conditional
                conditions:
                    state_not: 'off'
                card:
                  template: button
                  variables:
                    - name: Remote
                    - label: Control
                    - icon: mdi:remote
                    - show_state: false
                    - tap_action:
                        action: navigate
                        navigation_path: /lovelace/remote
                        haptic: light
                    - hold_action:
                        action: navigate
                        haptic: light
                    - opacity: 0.8
              # Button 2
                template: button
                variables:
                  - name: Scenes
                  - label: Presets
                  - icon: mdi:arrange-send-backward
                  - show_state: false
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/scenes
                      haptic: light
                  - hold_action:
                      action: navigate
                      haptic: light
                  - opacity: 0.8
              # Button 3
                template: button
                variables:
                  - name: Vacuum
                  - label: Bobot
                  - icon: mdi:robot-vacuum
                  - show_state: false
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/vacuum
                      haptic: light
                  - hold_action:
                      action: navigate
                      haptic: light
                  - opacity: 0.8
              # Button 4
                template: button
                variables:
                  - name: Menu
                  - label: All Options
                  - icon: mdi:menu
                  - show_state: false
                  - tap_action:
                      action: navigate
                      navigation_path: /lovelace/menu
                      haptic: light
                  - hold_action:
                      action: navigate
                      haptic: light
                  - opacity: 0.8
# The following config is for notifications on the frontpage
# For ease of use it is in a separate file.
    - !include ../notifications/notifications.yaml
05.devices.yaml:
- title: Devices
  path: devices
  popup_cards:
    !include ../popup-cards/device-popup.yaml
  cards:
      cards:
          template: header
          variables:
            - content: '## šŸ“ŗ Devices'
          template: header
          variables:
            - content: '##### Salon'
          cards:
              template: button
              variables:
                - entity: switch.salon_tv
                - name: Salon TV
                - icon: mdi:television
                - on_state_color: green
                - off_state_color: red
                - color: black
                - lock: false
                - grid:
              template: button
              variables:
                - entity: switch.yamaha_receiver_salon
                - name: Receiver Salon
                - icon: mdi:set-top-box
                - color: black
                - lock: false
                - grid:
              template: button
              variables:
                - entity: switch.receiver_zone_2
                - name: Receiver Zone 2
                - color: black
                - lock: false
                - grid:
          cards:
              template: button
              variables:
                - entity: switch.apple_tv
                - name: Apple TV
                - icon: mdi:apple
                - color: black
                - lock: false
                - variable: icon
                - grid:
              template: button
              variables:
                - entity: switch.salon_speaker
                - name: Salon Speaker
                - icon: mdi:cast-audio
                - lock: false
                - color: blue
                - variable: icon
                - grid:
            - type: 'custom:button-card'
              color_type: blank-card
              aspect_ratio: 1/1
          template: header
          variables:
            - content: '##### Office'
          cards:
              template: button
              variables:
                - entity: switch.office_speaker
                - name: Office Speaker
                - color: blue
                - variable: icon
                - grid:
              aspect_ratio: 1/1
              aspect_ratio: 1/1
          template: header
          variables:
            - content: '##### Bedroom'
          cards:
              template: button
              variables:
                - entity: switch.bedroom_speaker
                - name: Bedroom Speaker
                - color: blue
                - variable: icon
                - grid:
              aspect_ratio: 1/1
              aspect_ratio: 1/1
popup-cards:
device-popup.yaml:
#Devices
  switch.salon_media_system:
    title: Media System Salon
    style:
      color: white
      background: var(--background-image)
    card:
      cards:
          cards:
              template: more-info-popup
              variables:
          cards:
              variables:
          cards:
              variables:
        - !include ../includes/bottom-card.yaml
  switch.yamaha_receiver_salon:
    title: Yamaha Receiver Salon
    style:
      color: white
    card:
      cards:
          cards:
              variables:
  switch.salon_tv:
    title: TV Salon
    style:
      color: white
    card:
      cards:
          cards:
              variables:
  switch.apple_tv:
    title: Apple TV
    style:
      color: white
    card:
      cards:
          cards:
              variables:
  switch.salon_speaker:
    title: Salon Speaker
    style:
      color: white
    card:
      cards:
          cards:
              variables:
  switch.bedroom_speaker:
    title: Bedroom Speaker
    style:
      color: white
    card:
      cards:
          cards:
              variables:
  switch.office_speaker:
    title: Office Speaker
    style:
      color: white
    card:
      cards:
          cards:
              variables:
#Climate
  switch.salon_cool:
    title: Salon AC Fan Mode
    style:
      color: white
    card:
      cards:
        - type: conditional
          conditions:
            - entity: climate.salon_ac
              state_not: 'off'
          card:
            cards:
                cards:
                  - type: conditional
                    conditions:
                      - entity: input_select.salon_ac_fan_mode
                        state: low
                    card:
                      type: 'custom:decluttering-card'
                      template: button
                      variables:
                        - name: Low
                        - label: Mode
                        - icon: mdi:fan
                        - off_spin: true
                        - size: 15%
                        - show_state: false
                        - ha-card-background: var(--homekit-card-on)
                        - off_icon_color: Dodgerblue
                        - off_name_color: black
                        - off_label_color: gray
                        - opacity: 1.0
                        - tap_action:
                            service: input_select.select_option
                            service_data:
                              option: low
                              entity_id: input_select.salon_ac_fan_mode
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: low
                    card:
                      template: button
                      variables:
                        - name: Low
                        - label: Mode
                        - icon: mdi:fan
                        - size: 15%
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: low
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state: mid
                    card:
                      template: button
                      variables:
                        - name: Mid
                        - label: Mode
                        - icon: mdi:fan
                        - size: 20%
                        - off_spin: true
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: mid
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: mid
                    card:
                      template: button
                      variables:
                        - name: Mid
                        - label: Mode
                        - icon: mdi:fan
                        - size: 20%
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: mid
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state: high
                    card:
                      template: button
                      variables:
                        - name: High
                        - label: Mode
                        - icon: mdi:fan
                        - off_spin: true
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: high
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: high
                    card:
                      template: button
                      variables:
                        - name: High
                        - label: Mode
                        - icon: mdi:fan
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: high
                            haptic: light
                        - hold_action:
                            action: none
  switch.salon_heat:
    style:
      color: white
    card:
      cards:
        - type: conditional
          conditions:
              state_not: 'off'
          card:
            cards:
                cards:
                  - type: conditional
                    conditions:
                        state: low
                    card:
                      template: button
                      variables:
                        - name: Low
                        - label: Mode
                        - icon: mdi:fan
                        - off_spin: true
                        - size: 15%
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: low
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: low
                    card:
                      template: button
                      variables:
                        - name: Low
                        - label: Mode
                        - icon: mdi:fan
                        - size: 15%
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: low
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state: mid
                    card:
                      template: button
                      variables:
                        - name: Mid
                        - label: Mode
                        - icon: mdi:fan
                        - size: 20%
                        - off_spin: true
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: mid
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: mid
                    card:
                      template: button
                      variables:
                        - name: Mid
                        - label: Mode
                        - icon: mdi:fan
                        - size: 20%
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: mid
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state: high
                    card:
                      template: button
                      variables:
                        - name: High
                        - label: Mode
                        - icon: mdi:fan
                        - off_spin: true
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: high
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: high
                    card:
                      template: button
                      variables:
                        - name: High
                        - label: Mode
                        - icon: mdi:fan
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: high
                            haptic: light
                        - hold_action:
                            action: none
  switch.office_cool:
    title: Office AC Fan Mode
    style:
      color: white
    card:
      cards:
        - type: conditional
          conditions:
            - entity: climate.office_ac
              state_not: 'off'
          card:
            cards:
                cards:
                  - type: conditional
                    conditions:
                      - entity: input_select.office_ac_fan_mode
                        state: low
                    card:
                      template: button
                      variables:
                        - name: Low
                        - label: Mode
                        - icon: mdi:fan
                        - off_spin: true
                        - size: 15%
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: low
                              entity_id: input_select.office_ac_fan_mode
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: low
                    card:
                      template: button
                      variables:
                        - name: Low
                        - label: Mode
                        - icon: mdi:fan
                        - size: 15%
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: low
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state: mid
                    card:
                      template: button
                      variables:
                        - name: Mid
                        - label: Mode
                        - icon: mdi:fan
                        - size: 20%
                        - off_spin: true
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: mid
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: mid
                    card:
                      template: button
                      variables:
                        - name: Mid
                        - label: Mode
                        - icon: mdi:fan
                        - size: 20%
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: mid
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state: high
                    card:
                      template: button
                      variables:
                        - name: High
                        - label: Mode
                        - icon: mdi:fan
                        - off_spin: true
                        - show_state: false
                        - opacity: 1.0
                        - tap_action:
                            service_data:
                              option: high
                            haptic: light
                        - hold_action:
                            action: none
                  - type: conditional
                    conditions:
                        state_not: high
                    card:
                      template: button
                      variables:
                        - name: High
                        - label: Mode
                        - icon: mdi:fan
                        - show_state: false
                        - color: gray
                        - opacity: 0.4
                        - tap_action:
                            service_data:
                              option: high
                            haptic: light
                        - hold_action:
                            action: none
Thank again
Yes it seems popup cards no longer work in HA 101.3. Which is too badā€¦ I will look into it, however I think I will need to rewrite it to use browser mod instead as popup cards are deprecated.
For the time being, If you rely on those cards, I will suggest reverting to a version prior to 101.3
I am currently rewriting a lot of stuff (hence the long delay between updates) and it might take a while before I finish it. I might release a hotfix for the cards if it takes too long for me to finish up the next update. But notifications are undergoing a massive rewrite at the moment.
A preview of what has changed below in the screenshot. Notifications will scroll automatically in the new version and ofc popup cards will all be replaced with browser mod. Srry for the inconvenience!
Edit to the post above, I have looked into it and it seems that card-tools is the culprit here. If you revert card-tools to a version below 2.0 (donā€™t forget to refresh) it should work again. As popup cards are deprecated and card-tools is moving forward I will remove popup cards in any upcoming versions! For now you can just revert card-tools to an older version.
Yes Iā€™m using in card-tools version 2.0, so I will wait for new update of HKI
thank u @jimz011
After hours and hours I found the problem. In your button template it must be a variable:
show_entity_picture: true
So I love this and have spent the last couple days converting my setup ā€¦ all of a sudden today after resetting the frontend cache for another issue every button has the lock which I have to unlock (iOS beta 2.0) the regular app seems to work fine. I havenā€™t had the lock on any buttons (although they would show up in Firefox but I just ignored it because I donā€™t normally use it)
Any ideas what happened or how to get them back to normal l?
looks like you have button-card 3.0 and an older template of mine. Please use the latest button card template from my repo.
I have the one that lists changes from 0.13.3ā€¦ I recopied it from repo again for good measure, but still same issue. In the meantime I noticed they donā€™t appear in safari on my Mac.
EDIT
ā€¦ I reinstalled button-card and restarted HA and Iā€™m all good again!
Thanks this is amazing work youā€™ve done. I love my new setup!
Anyone know how to change the logbook text color for the item itselfā€¦ Iā€™ve tried a few changes under this section, but im not sure if they arenā€™t applying or if im in the wrong section all-together. (my css skills are limitedā€¦ I got out of the webpage game around the time when flash because a thingā€¦ :grimacing:)
34%20PM
# History/Logbook
lumo-primary-text-color: 'var(--light-primary-color)'
lumo-secondary-text-color: 'var(--light-primary-color)'
lumo-primary-color: 'var(--light-primary-color)'
lumo-body-text-color: 'AliceBlue' # Calendar Day
lumo-base-color: 'var(--mdc-grey-darken-4)' #Calendar/Date-Picker Background
lumo-header-text-color: 'var(--lumo-body-text-color)' #Month/Year header
