2020-01-27 19:53:31 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-27 19:53:31 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-27 19:53:33 WARNING (SyncWorker_18) [homeassistant.components.python_script] Folder python_scripts not found in configuration folder
2020-01-27 19:53:34 ERROR (MainThread) [homeassistant.setup] Setup failed for customizer: Integration not found.
2020-01-27 19:53:34 ERROR (MainThread) [homeassistant.setup] Setup failed for python_script: Integration failed to initialize.
2020-01-27 19:53:34 ERROR (MainThread) [homeassistant.setup] Setup failed for lovelace_gen: Integration not found.
2020-01-27 19:53:53 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2020-01-27 19:53:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/ping request
2020-01-27 19:53:53 WARNING (MainThread) [homeassistant.components.hassio] Not connected with Hass.io / system to busy!
2020-01-27 19:53:54 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry for hacs
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 215, in async_setup
hass, self
File “/config/custom_components/hacs/init.py”, line 65, in async_setup_entry
startup_result = await hacs_startup(Hacs)
File “/config/custom_components/hacs/init.py”, line 101, in hacs_startup
lovelace_info = await system_health_info(hacs.hass)
File “/usr/src/homeassistant/homeassistant/components/lovelace/init.py”, line 235, in system_health_info
return await hass.data[DOMAIN].async_get_info()
File “/usr/src/homeassistant/homeassistant/components/lovelace/init.py”, line 131, in async_get_info
config = await self.async_load(False)
File “/usr/src/homeassistant/homeassistant/components/lovelace/init.py”, line 145, in async_load
self._load_config, force
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/lovelace/init.py”, line 164, in _load_config
config = load_yaml(fname)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 62, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File “/usr/local/lib/python3.7/site-packages/yaml/init.py”, line 114, in load
return loader.get_single_data()
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 43, in get_single_data
return self.construct_document(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 47, in construct_document
data = self.construct_object(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 92, in construct_object
data = constructor(self, node)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 196, in _ordered_dict
nodes = loader.construct_pairs(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 147, in construct_pairs
value = self.construct_object(value_node, deep=deep)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 117, in _include_yaml
return _add_reference(load_yaml(fname), loader, node)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 227, in _construct_seq
(obj,) = loader.construct_yaml_seq(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 399, in construct_yaml_seq
data.extend(self.construct_sequence(node))
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 122, in construct_sequence
for child in node.value]
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 115, in _include_yaml
fname = os.path.join(os.path.dirname(loader.name), node.value)
File “/usr/local/lib/python3.7/posixpath.py”, line 94, in join
genericpath._check_arg_types(‘join’, a, *p)
File “/usr/local/lib/python3.7/genericpath.py”, line 153, in _check_arg_types
(funcname, s.class.name)) from None
TypeError: join() argument must be str or bytes, not ‘list’
2020-01-27 19:53:54 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Secret devicetracker_mattias not defined
2020-01-27 19:54:11 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform unifi is taking over 10 seconds.
2020-01-27 19:54:11 WARNING (MainThread) [homeassistant.components.device_tracker] Setup of device_tracker platform unifi is taking over 10 seconds.
2020-01-27 20:03:14 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for apple_tv which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-27 20:03:14 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2928621584] Error handling message: Unknown error
File “/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py”, line 20, in _handle_async_response
await func(hass, connection, msg)
File “/usr/src/homeassistant/homeassistant/components/lovelace/init.py”, line 187, in send_with_error_handling
result = await func(hass, connection, msg)
File “/usr/src/homeassistant/homeassistant/components/lovelace/init.py”, line 212, in websocket_lovelace_config
return await hass.data[DOMAIN].async_load(msg[“force”])
2020-01-27 20:24:27 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2924805200] Error handling message: Unknown error
