Homekit Infused 5 (HKI) v2023.1.3
yeah, already changing the notification card , already lots of less errors now :slight_smile:
thnx!
seems you used it also in header template, how did you replace that markdown there?
default:
  # Name/Title
  - content: content
# Card Config
# Do NOT change this unless you know what you are doing!
card:
  type: markdown
  # color changed to var(--header-color) # Changed/Added in 0.11.2
  style: |
    ha-card {
      box-shadow: none;
      height: 33px;
      background: none;
      padding: 0px 10px;
      color: var(--header-color);
  content: '[[content]]'
Haha, the code I shared was meant to replace the header text, not the notifications. If it did work for notifications then great. :stuck_out_tongue:
yeah, i noticed
i am at the moment replacing all notification-card to notification … almost done here :slight_smile:
jus one last question , in the header template
you could define like ## or #### and the text size was bigger …
how todo that now?
This is my current code, sorry I use lovelace_gen nowadays, but you should get the idea.
type: custom:button-card
style: |
  ha-card {
    margin-top: -5px;
name: "{{ name }}"
icon: "{{ icon|default('mdi:home') }}"
deep_press: {{ _global.deep_press.deep_press|default('false') }}
entity: {{ entity|default('input_boolean.dummy1') }}
show_state: false
show_label: false
show_icon: {{ show_icon|default('true') }}
tap_action:
  action: {{ tap_action|default('none') }}
  haptic: light
hold_action:
  action: {{ hold_action|default('more-info')}}
  haptic: heavy
######## EVERYTHING BELOW HERE HAS TO DO WITH STYLES!
styles:
  card:
    - --ha-card-background: rgba(0,0,0,0.0)
    - box-shadow: none
    - height: 45px
    - width: {{ width|default('350px') }}
  name:
    - font-size: "[[[ return states['input_select.name_font_size_selector'].state ]]]"
    - font-family: "[[[ return states['input_text.font_family'].state ]]]"
    - color: var(--header-color)
    - justify-self: {{ justify_self|default('start') }}
    - padding-left: {{ padding_left|default('13px') }}
    - font-weight: {{ font_weight|default('normal') }}
  img_cell:
    - align-self: start
    - text-align: start
    - margin-left: {{ margin_left|default('25px') }}
  grid:
    - grid-template-areas: '"i n"'
    - grid-template-columns: 8% 1fr
    - grid-template-rows: 1fr
  icon:
state:
  - value: "off"
    spin: {{ spin|default('false') }}
I have marked what piece you should look for and this will give you a basic idea of how to style your text. I have tried to make it exactly like the other one, but I did not succeed in doing that. However this comes pretty close.
ok, tnx a lot for info
appreciate it
ok, all markdown relations removed, but still lots of script errors, less then before, but still there :frowning:
ok, next up. Do you use the border-radius and box-shadow selectors I once introduced?
If yes then hardcode it to something you want, do this for all cards:
border-radius: 12px;
box-shadow: none;
this could be in a single card or in button card, just make sure you don’t miss one! This will probably help a lot! You could do even better by putting the variables inside your theme files and call them like this:
border-radius: var(--border-radius);
box-shadow: var(--box-shadow);
Edit: if you use conditional-cards (which show nothing atm because of the condition) this might also throw errors in the console.
ok, fixed some remaing border-radius, they were based of an inut select, that didnt excist, a few remaining, now hardcoded the
yes, i have indeed conditions that show nothing based, just to hide when its not needed
are those the culprit?
@jimz011 conditional card creates a lots of errors, i am converting them to state-switch… when no state-switch
but, it creates extra spaces between cards, if there is none displayed
doesnt mather if only 1 card is not displayed; but if there is like 10 cards between it, and thye are not displayed; it creates a hugh gap between it…did you encounter that too when you were using state-switch ?
Custom header has been updated for 107 as far as i can tell. Is it safe to try your setup out now with 107?
ever find out?
No unfortunately the latest updates did not fix HKI from working with 107/108 however I am working on a work around which I will release next week!
Cool. Waiting to try it out then.
Hows the update comming?
Release HKI 2.0.0 Beta 8
A little longer than you are used of me. Unfortunately unforseen things have been happening in my life lately, with the death of one of my family members and the ongoing worldwide crisis (in other words, a BIG chance to lose our jobs for some of us) I did not really felt compelled to work on Home Assistant a lot and I simply needed a break. But I am back with a ‘small’ update for you today. Enjoy!
HKI Beta 8 is now open for anyone to download: visit https://github.com/jimz011/homekit-infused for documentation and download.
Changes:
  • HKI is now compatible with HA 0.107.x, 0.108.x and 0.109.x!
  • The settings and the frontend now have their own dashboards (unfortunately because of the way resources are loaded I had to create a workaround which is a bit annoying, but unfortunately for now the only way to make custom-header work properly again with Home Assistant v 0.107.x and up. I will try to address this in the future, however it might take a long time before I find out what the exact problem is).
  • Removed all markdown cards in favor of button-cards (this should improve view loading)
  • Fixed swipe-card notifications looking weird
  • Fixed code for use with the latest version of button-card
  • Fixed bugs where lovelace would reach it’s max limit and force a reload (at least I think :P)
  • Fixed issue within the HA Settings view where it would not fire the reload automations button
  • Added bar-card to the resources (you can install this with HACS if you need this). This is currently not a requirement, however it will be used in the future as well as it is used in a great HKI addon created by @noodlemctwoodle (https://github.com/noodlemctwoodle/homeassistant)
  • Buttons in the HA Settings view will now ask for confirmation
  • Alarm Keypad removed for a simpler solution, you can set the alarm up in the interface (you must have a manual alarm set up for this to work)
  • The weather view is now in a vertical-stack making it uniform from the rest of the theme (this is only noticable on tablets and desktop browsers)
  • Fixed laundry widgets, they now shop up properly
  • Split up laundry widget (you can now show/hide the pictures individually instead of having either all 3 pictures or none enabled)
  • Added Hebrew language (Thanks to @avi)
  • Added Norsk language (Thanks to @wayller)
  • Added German language (Thanks to @manzn)
  • Added Romanian language (Thanks to @sergiu)
  • Added alternative Spanish language (Thanks to @sergiu). Please give me feedback on which Spanish version you use and if I should keep both in the setup!
  • Split up Name and Notifications font (you can now set the font size of the frontpage notifications separately)
  • Added new Font options (you can now set a font weight for names, states, labels, badges and notifications. This can be useful in languages like Spanish where the second word is more important). This change will mess with your fonts, press the reset fonts button in the Fonts Config to reset it to default!
  • Removed most icon and language input_text entities (this removes around 800 entities! Note that the endresult will be around the 400/500 entities removed as many have been added to accompany the new rooms and vacuum config)
  • Languages are now handled through scripts and appdaemon thanks to @hassan (please read the update guide below)
  • Icons are now handled through scripts and appdaemon thanks to @hassan (please read the update guide below)
  • More rooms are now available (5 basement level rooms, 10 ground floor rooms, 10 first floor rooms, 5 second floor rooms and 5 third floor rooms)
  • Rooms have to be setup in the UI now (you must renew your config on the rooms and do this in the UI)
  • Rooms in the lights and devices view can now be shown/hidden through the Rooms Config (you can no longer hide/show these rooms with the edit mode, only adding a lock can still be done through the edit mode)
  • Added partial RTL options (this is ideal for languages that read from Right to Left, the header will be added in the future). To enable this, enable it in the UI and uncomment the rtl line in user_content/extra_settings.yaml.
  • Border-radius and box-shadow options have been removed from the theme options, they can now be set within the user_content/themes/ folder (this is done to improve frontend performance)
  • Added a vacuum control panel (edit your view style with edit mode). To set this up go to HKI Settings > Vacuum Config (you MUST also set some extra variable within the extra_settings.yaml file)
  • Removed the option to set 3 columns on the frontpage buttons widget (this improves loading times and decreases the amount of code on the frontpage, if you did use three columns well, sorry but it’s a goner)
  • Removed option to set the column size on certain views within the UI, this can still be done but must now be done in the extra_settings.yaml file. (once again this is to lower the amount of code and improve performance).
  • Updated all plugins (only relevant if you did not install the plugins manually through HACS)
  • Changed style of all remaining markdown cards (to improve performance)
  • Lights and Devices views now have 5 floors available as opposed to the previous 3
  • Added Appdaemon4 (you must install this if you want b8 to work, read update guide below)
  • Hold actions can now also be invoked by a double tap on most buttons, e.g. when double tapping on a light it will open the slider popup (this makes it a lot easier to use on devices without 3D touch and more specifically Android devices)
  • Removed haptics from navigation buttons (this was requested). Reason? It is annoying on Android, whereas you barely notice it on iOS. Since I have an Android phone now I can see it is quite annoying.
  • Added widgets to the calendar view, it can now show the house calendar and a birthday calendar (set it up in the UI as usual). House calendar has been renamed to family calendar. You must set this up again if you already did in earlier beta’s.
  • Onboarding simplified to some help text, onboarding is still needed to fill in defaults (which is done by starting the onboarding). The initial process now only asks for icon sets and language. This is to lighten the onboarding process code as onboarding is only ever needed when installing for the first time.
  • Updated all addons/plugins to the latest available versions (if you don’t use HACS, download the updated resources from my repo /www/community/, else update them through HACS)
  • The HKI repo now has a direct download link on the homepage as opposed to the more ‘hidden’ link of previous betas.
  • Bugfixes
How to update?
Remember that you can only update from any version of 2.0.x. Older versions will not be updatable.
Update in the following order:
  • Make a backup of your config! DON’T FORGET THIS!!!
  • Add the following lines to your configuration.yaml and add replace the existing code:
lovelace:
  mode: yaml
  resources:
    !include_dir_merge_list dashboards/resources/
  dashboards:
    homekit-infused:
      mode: yaml
      title: HKI
      icon: mdi:cellphone
      show_in_sidebar: true
      filename: homekit_infused.yaml
    hki-settings:
      mode: yaml
      title: HKI Settings
      icon: mdi:tools
      filename: homekit_infused_settings.yaml
  • Update Home Assistant to the latest version! MAKE SURE you have checked all the breaking changes on the update part. I can not be held responsible for you not reading breaking changes. If you are not affected by any of these changes you can proceed to the next step. If not, fix it first. To make sure lovelace is not the culprit here you could simply comment the views line in ui-lovelace.yaml!
  • Install Appdaemon4 (if you use Homeassistant, previously Hass.io you can simply install this in the supervisor tab). Make sure you connect appdaemon to Home Assistant after you’ve installed it. (if you use hass.io you will only need to start the addon as config is already done for you!). If you use Home Assistant core please read up on how to install appdaemon4 here: https://appdaemon.readthedocs.io/en/stable/ (I have NOT tried this as I use Home Assistant aka Hass.io).
  • Remove the following folders from your HA setup: packages, lovelace.
  • Copy and paste/overwrite the following files/folders: python_scripts, themes, packages, dashboards, user_content/theme_settings/, appdaemon/apps/ and the files ui-lovelace.yaml, hki-settings.yaml, homekit-infused.yaml. (If you already use Appdaemon, please copy the file text_states_load.py to you /appdaemon/apps/ folder and copy the corresponding apps from apps.yaml into your own apps.yaml file)
  • Copy the user_content/extra_settings.yaml file to your user_content folder. WARNING: This will overwrite your existing config of that specific file. If you did make changes to this file you will have to set them again. Alternatively you could copy the contents of the new file to your existing file.
  • If you did not make any changes to the standard notifications file and other user_content you can simply copy over the entire folder and overwrite the old files. If you did make use of the user_content and IF you use any of the included templates you MUST change the path to those templates in each file. The old path will most likely look like ../lovelace/templates... or ../lovelace/includes.... Change the word lovelace to dashboards in EVERY file within your user_content folder. This folder must have the correct paths EVERYWHERE, it might take a while for you to adjust this. You MUST do this otherwise lovelace will fail to load the interface! Check all the files in your user_content folder and it’s subfolders to make sure this gets addressed! I will warn you again that it will NOT work if you don’t set it right!!!
  • Floors and Rooms can no longer be set in YAML (this is experimental as I am working on something better), please set them in HKI Settings > Room Config. Your old config will no longer work and this MUST be set within the UI!
  • Optional: Copy the user_content/vacuum_calibration.yaml file to your own user_content folder. You will only need this if you want to use the live vacuum map widget.
  • Optional: Cleanup entities, this release has over a 1000 less entities than beta 7 had, however Home Assistant will remember the last state of all these entities. Because it still loads all these entities you might find a slowdown in startup and when loading the database. Unfortunately there is no easy way to clean all the now ‘unavailable’ entities that you got throughout the beta’s. To clean the entities you MUST open configuration > entities (sidebar) on a desktop (will probably not load on a phone). You must then wait a few minutes as loading takes a while and then remove ALL unavailable entities one by one (you can sort them). Experienced users could also do this faster by editing the .storage/core.entity_registry file and remove all the related config (always make a backup of that file first!).
    You could also upgrade to HA 0.108.x as it speeds up the internal database by a massive margin. It will make opening the entities page in the UI MUCH faster, and a faster UI means faster deletion :P!
That is it for this beta, I know it doesn’t sound like much as it doesn’t really add many new features, but it should improve performance by quite a bit. I will still NOT recommend to install this on a rpi!
If you made a feature request and it isn’t in this beta? It might come in the next beta! If there are things you think I have forgotten or you think I should change or add please open an Issue or a Feature Request. Asking me personally or on one of my threads will not guarantee me looking at your problem. There are a lot of people that feel the need to address me personally and I will urge everyone that has questions to ask them in the homekit_infused channels on either the forums or discord. Asking in public benefits everyone as I will also answer your question publicly!
Thanks again and enjoy beta8!
Jimz011
This is beta 10 of HKI 2.0.0 (links in the first post)
Changes:
  • Fixed bug where it would not show the rooms in lights/devices view
  • Fixed bug where it would not show the floor selector in lights/devices view
  • Fixed bug that prevented the Romanian language from being selected
  • Fixed bug where it would not show thermostats on the climate page for some users
  • Fixed bug in the main menu’s edit mode, you can no longer select/create columns in the menu
  • Fixed bug where the initial onboarding process will take you to the wrong page
  • Added Covers view (this might not work as I can’t test it personally!), also added are cover view’s edit mode and all customizations that other views already can (e.g. change it’s header name, hide/show the widgets, user_content)
  • Added Covers to the device_counter.yaml file
  • Added Covers to the extra_settings.yaml file
  • Corrected documentation’s indentation
  • Removed python_script (this wasn’t needed and I had added it by accident, you can safely remove the entire folder if you don’t use python_scripts yourself)
  • Updated all addons/custom components on the repo (only useful for users that don’t use HACS)
  • Bugfixes
Unmentioned changes from beta 8/9:
  • Thermostat button actions have been reverted to its original behavior. This makes more sense with the rest of the setup.
How to update?
  • Step 1: remove the packages and dashboards folder (do NOT overwrite as it might leave deleted files). If you already use packages in your personal setup remove the HKI folders inside that folder instead.
  • Step 2: copy the new packages and dashboards folder to the root of your setup
  • Step 3: copy the user_content/views/covers_user_content.yaml file to your own user_content/views folder
  • Step 4: add the following line to your extra_settings.yaml file, make sure you only add the covers line as the header_secondary line already exists!
header_secondary:
  covers:
  • Step 5: add the following text to your device_counters.yaml file:
# All Covers
all_covers:
  entities:
# All Garage Doors
all_garage_doors:
  entities:
  • Step 6: You are done!
NOTE: To make the covers button work in both the menu and frontpage you MUST fill in a sensor badge (this is usually done at onboarding). I assume you have already done the onboarding process, so go to HKI Settings > Button Config > Covers and put either a device_counter entity or input_number.empty. THIS IS MANDATORY even if you do not plan to use this!
EXTRA NOTE: Some new text have been added and therefor languages previously translated might be incomplete (e.g. vacuum page is only translated in a few languages). If your language isn’t there you can either set it to English once and then back to your own language (this way at least the English titles will be there). Else fill in your own words which can be done in the HKI Settings > Other Translations. If you speak any of the included languages, please be so kind to fill in additional translations and send them back to me. If your language isn’t supported, you can always help me translating and it will be added in any of the upcoming versions.
Thanks and Enjoy!
Thanks for sharing this. How did you fix the not_home to Away?
@andrew.vint You once asked me to share what hardware I have used for everything.
I have updated the docs to include the hardware I have used for reference. You can check it out by clicking here.
@jimz011, need your help again
updated to 110 release, still using your old template, you had a quick access menu there with 3 buttons
that one is gone on every lovelace page ? i dont have a red error card there , like missing blabla, its just not there anymore
instead, i see below on every page now just a big black bar, with noting inside, not sure how to fix that?
edit: disregard that black bar issue, that was an issue with custom-header, seems fixed with a new release
i am just missing the quick access menu on every lovelace page and i dont know why
