Hi @jimz011.
Greatly appreciate your work.
Now I have finally made myself a frontend that I think is eye-catching to look at.
Like the idea of an overview of the care of your four-legged Tala. Could you please share sensor tamplates for “animals_tala *”? Not quite sure how I make a sensor that counts days, months etc.
Thanks in advance
Its actually a card that I didnt look into anymore since the dev had updated it. But if you are interested in making it into a custom view, the card that was used is called Check Button Card. It was relatively easy to setup and uses mqtt to count the days. Entities would be created by the card itself, though not sure how it works nowadays.
Hi again, trying to get my Sonos group/play control to work with mini-media-player. Tried to convert the working lovelace version to HKI, but it doesn’t give me the grouping features etc. Could somebody have a look and let me know what I’m missing? I tried adding the TYPE to all entities as well just to make sure, but it doesn’t give any grouping options…
Unfortunately, all the options given in the addons documentation is really all it can do. Even though the official docs state otherwise. You can however always create a custom view by adding the following in your view_config:
media:
icon: mdi:speaker
show_in_favorites: true
subtitle: Media
custom_cards:
position: bottom
and then create a folder named media in /hki-user/views/, you can then add custom code to that folder like you would any other card in YAML. Just create a file (name does not matter) inside of that folder that you have created e.g. /hki-user/views/media/sonos-card.yaml and then enter the code inside that file (with a leading hyphen)
# correct way (note the leading hyphen)
- type: markdown
content: The correct way
# incorrect way (not there is no leading hyphen)
type: markdown
content: The incorrect way
You can have multiple cards in a single file, or have each card live in a separate file, it is up to you, it will figure it out automatically.
However there is a sidenote, mixing custom views with HKI addons will definitely work, but it might look bad on desktops/tablets. Unfortunately there is nothing I can do about this without redesigning a lot of the current code (which will definitely break anyones config). And since HKI has been running steadily for pretty much its entire 4th iteration I’d prefer to keep it this way for now (since I don’t have much time to rework it at the moment).
It will look absolutely fine on mobile devices though since they only show cards vertically. My suggestion would be to either play around with it and see what fits your needs best. You can make addons with custom cards work, but I will recommend you to go one way or the other on a given view since that will look best. You can also make great use of it when running it with the view_selector addon which will make the use of addons and custom_cards at the same time a bit better.
Thank you so much for your detailed write-up. The mini-media-player works brilliantly in every other way, just missing that speaker group option to control the groups. This is not something easily added as I understand it? It’s natively supported by the mini-media-player card.
I will give your workaround a go to see if it looks ok. I will potentially open some more options with the layouts, buttons etc, and might be the easiest. Thanks!
Hey, back with another question. I would like to have a picture-elements style card on my frontpage that shows my car and some details from it. However I can’t see that I can get picture-elements on there in any way? I see from 3.x.x there is a legacy add-on that is called car-card and is probably used similarly to the application-card. Is that my best option? Would be good to see the quick status of the car on the homepage, but I can live with using a view for it.
hi jimz, thanks for your reply.
I’ve already tried these templates and I’m starting to get to know them a bit but which template should I use to get a layout like with the lights?
By reading the doc and taking example on the lights, I made a copy/paste by adapting my need (3 shutters)
1/ in /config/hki-user/config/general_config.yaml (last three lines):
# Header ################################################################################################################################
header:
show_sensors: true
sensors: # You can remove the sensors you don't want to show, you can have as many as you want. Note: Leaving group_entity empty will disable it's popup but still show the number.
- icon: mdi:motion-sensor
entity: sensor.current_binary_sensors_on
group_entity: group.all_binary_sensor_entities
- icon: mdi:door
entity: sensor.current_doors_open
group_entity: group.all_door_sensor_entities
# - icon: mdi:window-closed
# entity: sensor.current_windows_open
# group_entity: group.all_window_sensor_entities
- icon: mdi:window-shutter-open
entity: sensor.current_covers_open
group_entity: group.all_cover_entities
