just installed the HKI v 4.0.0 and having an error on mobile view through HA App.
Under Menu I can not see HomeKit Infused Base Settings, on desktop browser they are there.
Nothing changed on the code so far. What can be the problem?
I have same problem as you. On my dev homeassistant I tried upgrade to version 2021.11.3 but problem still remained. I returned the version 2021.11.1 to which it was no problem but now there is a problem here as well. There is no error in the log. What could it be?
Thank you for your answers.
@menealphion and @luckies and ofcourse anyone else with this problem. I see that this is now an issue. This means I will push an update soon that fixes this. Do not expect great new features currently (however I will continue the work on this project soon). As some of you might know now, my time is currently extremely limited.
But this seems to be a very annoying bug which I will sort out this weekend. Keep a close eye on the github repo!
People that are following this project and eagerly waiting for an update (since it hasnât been updated in months) I do have some good news.
Here is a draft of the upcoming changes. Expect this update to drop within a few days!
Addons:
- Logbook Card
- Statistics Card
- Energy Cards
- Glance Card
- History Card
- Gauge Card
- Plant Status Card
- Alternative Vacuum Dashboard
Fixes:
- Fixed icon in HA Settings
- Fixed HKI menu (this now shows properly again)
- Removed the now deprecated GUI Sandbox Tool, this is also no longer a requirement to install HKI.
- Fixed the FindMy addon, this will now show properly on desktops/tablets
- Upgraded the Vacuum Map addon to support v2
Features added:
- Covers support (thanks to @........?)
- Added heat/cool and heat_cool to the climate devices sensor
- The columns addon now has a global value for gauges
Other:
- Removed RC status
- Version scheme changed in a format also used by HA, meaning it will now show the year, month and the version number (e.g. 2021.11.3, this means it is published in 2021 in the month of November and that it is the third version of that month. Note that the HKI version is not tied to HA versions and thus a higher HA version does not mean HKI with a lower numbered version will not work with them. The original HKI compatibility sensor will remain and thus there are no changes in that area.
Issues:
- The extra options on the navigation bar to show user/date/time or a custom text are currently not working until a fix is found to work with the latest HA versions. All other functions seem to be unaffected.
*New addons and hotfixes
Changes:
To Do:
You can expect the Vacuum and Cover addons to be added in v2021.12.x
BREAKING CHANGES
No specific breaking changes, however if you want to use thermostats or covers in your headers device counters than you must add a few lines to your /hki-user/config/general_config.yaml
file.
Look for lines 15 to 20 in the default config file
How to Update?
*NOTE: CREATE A BACKUP BEFORE UPDATING!!!
Make sure you update all the custom cards and addons to their latest versions!
Download the release, then copy and overwrite the following two folders:
/hki-base/
/packages/
Restart your Home Assistant!
NOTES:
Please check out my personal repo for examples with the v4.x.x config GitHub - jimz011/homekit-infused at 4.x.x-personal
I have some great great news for people using this dashboard with custom cards
Starting from version 2021.12.1 HKI will get a new addon called custom:
which lets you add ANY card you want straight from the view config.
This does a few thing:
custom_cards:
addon which will be removed from HKI starting v2022.1.1*The ultimate addon: Custom!
Changes:
The new CUSTOM addon
You can now add any card you want to HKI, yes this was already possible, however it can now be done straight from the view_config! Here is a short list of what it will and wonât do:
layout:
and entities_card:
!BREAKING CHANGES
Layout addon has now more options, because of this change the way we get those options have slightly changed. If you did use the layout-card addon and had set optional layout
options, you will nog have to change your formatting.
# Previous way
my_view:
layout:
column_widths: 7fr
max_width: 100%
# New way
my_view:
layout:
options:
- column_widths: 7fr
max_width: 100%
I know it is slightly more code, but it now opens up many new options for layout-card, which you can find in the layout addon documentation now!
custom_cards:
, this addon will deprecate in a later version of HKI, but I want to mention it now so that you will start migrating!
How to Update?
/hki-base/
/packages/
*Bugfixes for the custom addon
Changes:
custom_position:
that was introduced in HKI 2021.12.1 is no longer available and now merged with the custom addonBREAKING CHANGES
The option custom_position:
in the global config is no longer available, this must now be set individually per stack, this makes creating something you want a lot easier.
If you did not use the new custom:
addon, or if you did not use the custom_position:
option, this does not apply to you.
This also does not apply to the older custom_cards:
addon!
How to Update?
/hki-base/
/packages/
Hello @jimz011
Im sorry for my stupid question, but I dont understand the new custom
card. I have many old custom_card
and I dont know how can I added to new custom
card.
This is one of many:
- type: custom:mod-card
style: |
ha-card {
margin-left: 7px;
margin-right: 7px;
card:
type: vertical-stack
cards:
- !include
- '../../../hki-base/templates/other/title-text.yaml'
- name: 'Server Resources'
- type: horizontal-stack
cards:
- !include
- '../../../hki-base/templates/other/mini-graph.yaml'
- entity: sensor.processor_use
line_color: '"#00d8ff"'
graph_type: line
line_width: 8
decimals: 0
show_extrema: true
show_name: true
font_size: 85
height: 100
- !include
- entity: sensor.memory_use_percent
graph_type: line
line_width: 8
decimals: 1
show_extrema: true
show_name: true
font_size: 85
height: 100
How can I added to new custom
card? Because when I did this, HA didnt load anymore.
Here is my view_config.yaml
system:
icon: mdi:home-assistant
subtitle: Overview
show_in_favorites: false
show_subtitle: true
show_in_menu: true
button_label: Overview
button_badge: sensor.average_cpu_temperature
custom:
!include ../../hki-user/views/system/system.yaml
Thanks for your hard work on this project (it`s best of best).
Try this @luckies
custom:
- cards:
However Iâd advise you to use the new format which has the title text already baked in.
You will get something like this:
system:
subtitle: Overview
show_subtitle: true
show_in_menu: true
custom:
- title: Server Resources
cards:
cards:
- !include
- '../../hki-base/templates/other/mini-graph.yaml'
graph_type: line
line_width: 8
decimals: 0
show_extrema: true
show_name: true
font_size: 85
height: 100
- !include
graph_type: line
line_width: 8
decimals: 1
show_extrema: true
show_name: true
font_size: 85
height: 100
@luckies the example above can be split into another file as well, youâd get this:
# view_config.yaml
system:
subtitle: Overview
show_subtitle: true
show_in_menu: true
custom:
!include ../../hki-user/views/server.yaml
# ../../hki-user/views/server.yaml
cards:
- !include
graph_type: line
line_width: 8
decimals: 0
show_extrema: true
show_name: true
font_size: 85
height: 100
- !include
graph_type: line
line_width: 8
decimals: 1
show_extrema: true
show_name: true
font_size: 85
height: 100
As you can see, multiple ways to do it, but the new custom addon already takes away your first 12 lines, since you no longer have to add them yourself
The same is true for the layout addon, this now works great with custom cards as well.
*Note: take note of the path that changes when using split files, I have corrected paths in both examples.
*Finally some attention to themes!
Changes:
How to Update?
/hki-base/
/packages/
Hi @jimz011
thanks for your quickly answers, but I have still same problem. When I added new custom
card config, restart HomeAssistant, I get this error ERROR (MainThread) [root] Uncaught exception
and HA didnt load anymore (bootloop).
I tried all possibilities config options that you mentioned above. When I use custom card without !include
any template, its worked. I have no idea whatâs wrong.
Thanks for your help.
Seems to be a bug in the latest version, will fix it soon.
I too have this problem sometimes, but it depends on screen and column size.
There are new vacuum controls on the way, so stay tuned.
hi jimz
thx for the answer, i wil wait for the update
another question,
if i want to use a custom view, can i use a own pop up card? so yes can u give an example how to?
great work
Yes the custom addon will allow you to create any config possible. But it is a bit advanced. You will have to learn to use the following two HA addons, namely browser_mod and button-card. A big update coming to the HKI devices addon is coming real soon which will have such things preprogrammed so that you will only need to add a few lines of code to achieve it.
Hi @jimz011
its possible to make a layout like in the picture? Or do I have to do it via custom
addon?
Thanks for any answers.
# view_config.yaml
system:
subtitle: Overview
show_subtitle: true
show_in_menu: true
layout:
options:
- max_cols: 3
graphs:
columns: 2
entities:
show_icon: false
font_size: 85
height: 100
line_width: 8
show_extrema: true
show_icon: false
font_size: 85
height: 100
line_width: 8
show_extrema: true
- title: Server Temperatures
columns: 2
line_color: gold
entities:
- entity: sensor.cpu_temp
line_width: 8
decimals: 0
show_icon: false
show_extrema: true
show_name: true
font_size: 85
height: 100
- entity: sensor.cpu_temp_3
line_width: 8
decimals: 0
show_icon: false
show_extrema: true
show_name: true
font_size: 85
height: 100
devices:
- title: Server Overview
entities:
- entity: sensor.disk_free_home
show_last_changed: true
- entity: sensor.disk_use_home
- entity: sensor.disk_use_percent_home
name: SSD Used (%)
- entity: sensor.manager_mqtt_messages_s
label: Messages (Meross)
- entity: sensor.cert_expiry_timestamp_xxx
icon: mdi:certificate
label: xxx
show_state: false
- entity: sensor.ha_uptime
show_state: false
- entity: sensor.network_throughput_in_ens18
label: Through (MB/s)
- entity: sensor.network_throughput_out_ens18
@jimz011 I am also having issues getting custom cards to load in 12.3. Is anything wrong in my configuration?
security:
subtitle: "[[[ return `Alarm ${states['alarm_control_panel.alarm'].state}`; ]]]"
icon: mdi:shield
show_in_favorites: true
show_in_navbar: true
button_badge: sensor.current_binary_sensors_on
button_label: "[[[ return `Alarm ${states['alarm_control_panel.alarm'].state}`; ]]]"
custom:
cards:
- type: custom:alarmo-card
entity: alarm_control_panel.alarm
keep_keypad_visible: true
button_scale: 1
Try to make a list of the first part as well:
custom:
- cards:
