Homekit integration issues - it keeps adding unwanted entities
I just started to play with this integration and I configured the HA Bridge as suggested. I set it up to certain domains only and set the filter to include mode. I then include only certain entities, but when I open the Home app on my iPhone I keep seeing entities that I didn’t include in the configuration.
Is that something I can fix or should I go with the Homekit integration through the configuration.yaml ?
Have the same problem.
Did you find a solution
No, I just stopped using that integration
