Hello, hope you all can help me out with the following question about the homekit integration that I don’t fully understand. Even better would be if a few of you could give me some examples of your homekit integration portion of your config.yaml so that I can learn by seeing.
The first question I have is, if I load my entities by doing everything within the yaml, what will that look like if I am wanting to do both items like lights that don’t need accessory mode and a few door locks which require the accessory mode.
Also, is there no way to tell homekit what room to put the entity in within the config? Below is an example of my current configuration for the homekit section of my configuration.yaml.
Most important question I have in this thread is the below:
It revolves around the entities that need to be added in accessory mode. If I have added my bridge through yaml (as in the example below) and I now see the bridge on the integrations page, can I now add the accessory mode entities through the UI?
Thank you all for any help you can give me. (The below works well for all items that don’t require accessory mode, but as soon as I add the last 10 or so lines starting at -name: Front Door Lock, I get a configuration error popup)I don’t know how to finish this .yaml with regards to making it work for the remotes–i.e. harmony hubs and locks)
In the end, I would like to have my lights, switches, garage door, scripts, harmony hubs (I have 2), and door locks in homekit when I call this complete.
Thank you all again for any help/guidance you can give.
filter:
# include_domains:
# - alarm_control_panel
# - light
# - media_player
# - script
# - vacuum
# - binary_sensor
# - climate
# - cover
# - device tracker
# - fan
# - light
# - sensor
# - switch
include_entities:
- alarm_control_panel.alarmo
- climate.thermostat
- cover.garage_door
- fan.master_bedroom_ceiling_fan
- light.back_porch_light
- light.dining_room_light
- light.front_porch_light
- light.garage_accents
- light.gym_cabinet
- light.gym_power_rack
- light.hallway_light
- light.kitchen_light
- light.left_vols_light
- light.living_room_light
- light.master_bedroom_bed_accents
- light.master_bedroom_light
- light.right_vols_light
# - lock.530i_xdrive_lock
# - lock.back_door_lock
# - lock.front_door_lock
# - lock.garage_entry_door_lock
# - remote.harmonyhub_living_room
# - remote.harmonyhub_master_bedroom
- script.start_muscle_hustle
- script.stop_muscle_hustle
- switch.back_hallway_outlet
- switch.back_porch_fountain
- switch.back_porch_speaker_power
- switch.dining_room_outlet_left
- switch.dining_room_outlet_right
- switch.front_porch_fountain
- switch.front_porch_speaker_power
- switch.guest_bedroom_outlet_left
- switch.guest_bedroom_outlet_right
- switch.gym_outlet_left_right
- switch.gym_outlet_right_left
- switch.gym_outlet_center_left
- switch.gym_outlet_center_right
- switch.hallway_outlet
- switch.master_bedroom_floor_fan_power
- switch.master_bedroom_outlet_right
- switch.projector_power
entity_config:
alarm_control_panel.alarmo:
code: 631131
climate.thermostat:
cover.garage_door:
fan.master_bedroom_ceiling_fan:
name: Master Bedroom Ceiling Fan
light.back_porch_light:
name: Back Porch Light
light.dining_room_light:
name: Dining Room Light
light.front_porch_light:
name: Front Porch Light
light.garage_accents:
light.gym_cabinet:
light.gym_power_rack:
name: Gym Power Rack
light.hallway_light:
light.kitchen_light:
light.left_vols_light:
name: Left Vols Light
light.living_room_light:
name: Living Room Light
light.master_bedroom_bed_accents:
name: Master Bedroom Bed Accents
light.master_bedroom_light:
name: Master Bedroom Light
light.right_vols_light:
name: Right Vols Light
lock.530i_xdrive_lock:
name: 530I Xdrive Lock
code: 631131
# lock.back_door_lock:
# name: Back Door Lock
# code: 631131
# lock.front_door_lock:
# name: Front Door Lock
# code: 631131
# lock.garage_entry_door_lock:
# name: Garage Entry Door Lock
# code: 631131
# remote.harmonyhub_living_room:
# name: Harmonyhub Living Room
# remote.harmonyhub_master_bedroom:
# name: Harmonyhub Master Bedroom
script.start_muscle_hustle:
name: Start Muscle Hustle
script.stop_muscle_hustle:
name: Stop Muscle Hustle
switch.back_hallway_outlet:
name: Back Hallway Outlet
switch.back_porch_fountain:
name: Back Porch Fountain
switch.back_porch_speaker_power:
name: Back Porch Speaker Power
switch.dining_room_outlet_left:
name: Dining Room Outlet Left
switch.dining_room_outlet_right:
name: Dining Room Outlet Right
switch.front_porch_fountain:
name: Front Porch Fountain
switch.front_porch_speaker_power:
name: Front Porch Speaker Power
switch.guest_bedroom_outlet_left:
name: Guest Bedroom Outlet Left
switch.guest_bedroom_outlet_right:
name: Guest Bedroom Outlet Right
switch.gym_outlet_left_right:
name: Gym Outlet Left Right
switch.gym_outlet_right_left:
name: Gym Outlet Right Left
switch.gym_outlet_center_left:
name: Gym Outlet Center Left
switch.gym_outlet_center_right:
name: Gym Outlet Center Right
switch.hallway_outlet:
switch.master_bedroom_floor_fan_power:
name: Master Bedroom Floor Fan Power
switch.master_bedroom_outlet_right:
name: Master Bedroom Outlet Right
switch.projector_power:
- name: "Front Door Lock"
port: 51828
mode: accessory
filter:
include_entities:
entity_config:
