Homekit/libavahi
I installed Home Assistant on Raspberrypi 3B+ from image. This means I have never accessed the Raspberrypi itself. This means I have only been working within Home Assistant. Now I want to install HomeKit in HA and it is recommended that I download an additional package using:
$ sudo apt-get install libavahi-compat-libdnssd-dev
How do I go about doing that?
Thanks for your help.
Have you installed hassio or hassbian?
It is hassio
The instructions you are reading are not for hassio, which is a completely different operating system, and does not allow installation from apt.
I suggest you change the category of this post to HASSIO (the All-In-One installer was deprecated months ago) and see if you get any help on how to run homekit there.
Ok - I will do that. In which way deprecated?
The All-in-one installation method is no longer updated. It may not even work. It was largely replaced by hassio.
I see. But using the image is still OK?
The all-in-one installer did not use an image, it was a script to install HA on raspbian. It has nothing to do with hassio.
OK - thank you. Didn’t know that.
