Hi All, I have searched around the forums for this issue and whilst it has been discussed before it seems to have been some time ago and I am looking to see if anyone else is impacted with the current versions of all systems involved.
Problem: Home Assistant hosted devices showing as “No Response” in Apple Homekit.
System setup
- Rapsberry Pi hosted Home Assistant
- Core2024.4.1
- Supervisor2024.04.0
- Operating System12.1
- Frontend20240404.1
- 1 Apple TV 4K 1st Gen acting as the hub running tvOS 17.4
- iPhone, iPad and Macbook all on their respective lastest versions as of today.
- Single wifi network, not meshed, both all involved devices connected via the same wifi network
Possible causes: The most recent change was an upgrade to the latest Apple Homekit Architecture.
What I have tried to fix the issue:
- Wiped Raspberry Pi and started with a clean setup
- Factory restored Apple TV
- Removed all devices from Apple Home, deleted home and started again.
Short term work around
If I reboot the Apple TV, everything comes good for several hours, before becoming unresponsive again. Then another reboot of the Apple TV brings everything back again, I can’t keep rebooting the Apple TV to turn the lights on.
Anyone else on the latest version of everything and seeing or not seeing this issue?
