Hi all, I do all my automations in NodeRed, however I still had the problem that when I control things via HomeKit I could not detect any “manual” interaction.
In NodeRed the UserID is “null”, so I used the following trick:
I have created a “dummy light” in NodeRed with the help of “node-red-contrib-homekit-bridged” Which I grouped in HomeKit with the existing light. So I get in NodeRed the commands which are made via HomeKit
So if I use my HomePod to set the light to 10% I have the interaction through HomeKit and can perform other actions.
I hope maybe I helped someone, maybe I am making a huge mistake in thinking and it would be much easier.
NodeRed Flow:
"id": "bea273171c4eef3d",
"type": "homekit-service",
"z": "2c273b3d00ef04b6",
"isParent": true,
"hostType": "0",
"bridge": "8751eba15e8a503b",
"accessoryId": "",
"parentService": "",
"name": "Spot Sync",
"serviceName": "Lightbulb",
"topic": "",
"filter": false,
"manufacturer": "Dodo",
"model": "SYNC",
"serialNo": "1.0.0",
"firmwareRev": "1.2",
"hardwareRev": "1.0.0",
"softwareRev": "1.0.0",
"cameraConfigVideoProcessor": "ffmpeg",
"cameraConfigSource": "",
"cameraConfigStillImageSource": "",
"cameraConfigMaxStreams": 2,
"cameraConfigMaxWidth": 1280,
"cameraConfigMaxHeight": 720,
"cameraConfigMaxFPS": 10,
"cameraConfigMaxBitrate": 300,
"cameraConfigVideoCodec": "libx264",
"cameraConfigAudioCodec": "libfdk_aac",
"cameraConfigAudio": false,
"cameraConfigPacketSize": 1316,
"cameraConfigVerticalFlip": false,
"cameraConfigHorizontalFlip": false,
"cameraConfigMapVideo": "0:0",
"cameraConfigMapAudio": "0:1",
"cameraConfigVideoFilter": "scale=1280:720",
"cameraConfigAdditionalCommandLine": "-tune zerolatency",
"cameraConfigDebug": false,
"cameraConfigSnapshotOutput": "disabled",
"cameraConfigInterfaceName": "",
"characteristicProperties": "{\"Brightness\":true,\"Hue\":true,\"Saturation\":true}",
"waitForSetupMsg": false,
"outputs": 2,
"x": 1150,
"y": 880,
"wires": [
"633143413cbd4009"
"id": "7c9f643168e6c2f5",
"type": "server-state-changed",
"name": "Spot on",
"server": "707fb62d.6e7a88",
"version": 3,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "light.bath_spots",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": true,
"for": 0,
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 770,
"y": 860,
"wires": [
"02da18b67d20b65f"
"id": "02da18b67d20b65f",
"type": "change",
"name": "set on - true",
"rules": [
"t": "delete",
"p": "payload",
"pt": "msg"
"t": "set",
"p": "payload.On",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 950,
"y": 860,
"wires": [
"bea273171c4eef3d"
"id": "fbd8f2695665453b",
"name": "Spot off",
"version": 3,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"haltifstate": "off",
"outputs": 2,
"for": 0,
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 770,
"y": 920,
"wires": [
"a050ad08145df96d"
"id": "a050ad08145df96d",
"type": "change",
"name": "set on - false",
"rules": [
"t": "delete",
"p": "payload",
"pt": "msg"
"t": "set",
"p": "payload.On",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 950,
"y": 920,
"wires": [
"bea273171c4eef3d"
"id": "633143413cbd4009",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1350,
"y": 880,
"wires": []
"id": "8751eba15e8a503b",
"type": "homekit-bridge",
"bridgeName": "Demo Dodo",
"pinCode": "153-10-538",
"port": "",
"advertiser": "bonjour-hap",
"allowInsecureRequest": false,
"model": "Demo",
"serialNo": "1.1.2",
"firmwareRev": "",
"hardwareRev": "",
"softwareRev": "",
"customMdnsConfig": false,
"mdnsMulticast": true,
"mdnsInterface": "",
"mdnsPort": "",
"mdnsIp": "",
"mdnsTtl": "",
"mdnsLoopback": true,
"mdnsReuseAddr": true,
"allowMessagePassthrough": true
"id": "707fb62d.6e7a88",
"type": "server",
"name": "Home Assistant",
"version": 2,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30
