Homekit not updated when switch is turned on through google
I have homekit working pretty well with just a simple config:
homekit:
  auto_start: false
  filter:
    include_entities:
      - light.zipato_rgbw_led_bulb_level
      - light.zipato_rgbw_led_bulb_level_2
      - light.zipato_rgbw_led_bulb_level_3
      - light.fibaro_system_fgd212_dimmer_2_level_3
      - switch.fibaro_system_fgwpe_f_wall_plug_switch
      - switch.wifi_dru_module_switch
      - light.fibaro_system_fgd212_dimmer_2_level_5
      - sensor.netatmo_woonkamer_health
      - sensor.netatmo_woonkamer_humidity
      - sensor.netatmo_woonkamer_co2
      - light.fibaro_system_fgd212_dimmer_2_level_7
      - light.fibaro_system_fgd212_dimmer_2_level_9
      - switch.qubino_zmnhadx_flush_1_relay_switch
      - switch.toilet_lamp_1e_switch
      - switch.boiler_relay_switch
      - switch.duco_ventilatie_switch_2
      - switch.duco_ventilatie_switch_3
      - switch.keuken_switch
      - switch.badkamer_lamp_switch
      - sensor.netatmo_badkamer_humidity
      - sensor.netatmo_slaapkamer_temperature
      - sensor.netatmo_slaapkamer_co2
      - sensor.netatmo_studeerkamer_co2
      - sensor.netatmo_badkamer_temperature
      - sensor.netatmo_studeerkamer_temperature
      - sensor.netatmo_woonkamer_temperature
      - switch.qubino_zmnhbdx_flush_2_relays_switch
      - switch.muziek
      - switch.fibaro_system_fgwpe_f_wall_plug_gen5_switch
  entity_config:
    light.zipato_rgbw_led_bulb_level_3:
    light.zipato_rgbw_led_bulb_level_2:
    light.zipato_rgbw_led_bulb_level:
    light.fibaro_system_fgd212_dimmer_2_level_3:
      name: Woonkamer spot voor
    switch.fibaro_system_fgwpe_f_wall_plug_switch:
    switch.wifi_dru_module_switch:
    light.fibaro_system_fgd212_dimmer_2_level:
    light.fibaro_system_fgd212_dimmer_2_level_5:
    sensor.netatmo_woonkamer_health:
    sensor.netatmo_woonkamer_humidity:
      name: Woonkamer vochtigheid
    sensor.netatmo_woonkamer_co2:
    light.fibaro_system_fgd212_dimmer_2_level_7:
    light.fibaro_system_fgd212_dimmer_2_level_9:
    switch.qubino_zmnhadx_flush_1_relay_switch:
    switch.toilet_lamp_1e_switch:
    switch.boiler_relay_switch:
    switch.duco_ventilatie_switch_2:
    switch.duco_ventilatie_switch_3:
    switch.keuken_switch:
    switch.badkamer_lamp_switch:
    sensor.netatmo_badkamer_humidity:
      name: Badkamer vochtigheid
    sensor.netatmo_slaapkamer_temperature:
      name: Master bedroom temperatuur
    sensor.netatmo_slaapkamer_co2:
      name: Master bedroom CO2
    sensor.netatmo_studeerkamer_co2:
    sensor.netatmo_badkamer_temperature:
      name: Badkamer temperatuur
    sensor.netatmo_studeerkamer_temperature:
      name: Studeerkamer temperatuur
    sensor.netatmo_woonkamer_temperature:
      name: Woonkamer temperatuur
    switch.qubino_zmnhbdx_flush_2_relays_switch:
      name: Woonkamer spots achter
    switch.muziek:
    switch.fibaro_system_fgwpe_f_wall_plug_gen5_switch:
If I however turn on a switch through google home the status of the switch in homekit is not updated. Can this be done (does homekit update through mqtt?) or is this not possible
@tomdh76 Does the state of the switch inside Home Assistant change?
The switch in home assistant also does not change. So it has to do something with google home… Suggestions or should I ask in other forum?
I don’t have any experience with Google Home, so it might be best to search the forum or open a new thread for it.
Tell me… what’s this duco? Are you able to control your duco ventilation with proprietary zwave controller?
Maybe a bit off topic, but yes I can control the duco with homeassistant and a z w ave stick. the duco is connected to a qubino ZMNHBDx Flush 2 Relays
That misleading :slight_smile: you use 2 relays via “another zwave” :wink:
