I did nothing to the actual device’s link with Home Assistant (which happens to be zigbee).
What I did was:
Commented out the entity from the include_entities: list in HomeKit’s config (I only explicitly add devices, no catch-all becasue HomeKit gets infested by booleans and such)
Restart HA
Reopen HK until the cover is gone
Un-comment the cover entity (effectively include it) in HomeKit’s config
Thanks for the tip @sarrchini. I tried it, but to no avail. The problem with me is weird. It’s only the voice command that’s not working. The representation in HA and HK is fine. Only problem there is the curtains are represented as a roller blind. But to open I have to say: close curtain and vice versa. I could live with that if the voice command worked.
I’ll set a reminder @bogus when I get back home in about 2 weeks.
I’ve never used voice commands but I’ll test it out and tell you the outcome. I assume you mean you ask Siri to open and close.
Alrght, got home later than forecasted. I think it mught be device specific? Just tested my blinds with HA/Home App/Siri and it behaves as expected. I must say that my curtains are controlled by a zigbee device that reports %open/closed so there’s no template involved or anything. Sorry I can’t be of more help…
