Homemade thermostat to control from ha
Hello.
I’m trying to make a homemade thermostat to control from ha. The tactic is as follows: less than 20 nothing works, turns on from 20 to 30 hysteresis 0.5
How can I get hysteresis from the assistant? And apply this in a lambda?
Controlling tp_global u ha via input_number
Check out my code) can it be optimized?
This is not how it works, only manual numbers …
Not WORK if (id(tp_obratka).state < (id(tp_global) - id(tp_gist)))
work  if (id(tp_obratka).state < id(tp_global) - 0.5 )
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
globals:
 - id: tp_start
   type: int
   restore_value: no
   initial_value: '28'
 - id: tp_global
   type: int
   restore_value: no
   initial_value: '30'
 - id: tp_gist
   type: int
   restore_value: no
   initial_value: '0.5'
status_led:
  pin:
    number: GPIO13
    inverted: false
binary_sensor:
  - platform: status
dallas:
  - pin: GPIO14
    update_interval: 2s
  - platform: wifi_signal
    update_interval: 60s
  - platform: dallas
    address: 0xF33C01B556F0A928
    on_value:
      then:
        - script.execute: tp_control
  - platform: dallas
    address: 0xFE0119212D102B28
    on_value:
      then:
  - platform: homeassistant
    entity_id: input_number.tp_ustavka
    on_value:
       then:
        - script.execute: tp_globalset
switch:
  - platform: gpio
    pin: GPIO12
script:
  - id: tp_control
    then:
      - lambda: |-
         if (id(tp_podacha).state > 20 ) {
                    if (id(tp_obratka).state < (id(tp_global) - id(tp_gist))) {
                     id(tp_nasos).turn_on();
                } else if (id(tp_obratka).state > id(tp_global) ) {
                   id(tp_nasos).turn_off();
                }  else {
  - id: tp_globalset
    then:
     - globals.set:
          value: !lambda |-
            return id(tp_ustavka).state;
You don’t have code for all conditions.
	 //NOTHING HAPPENS WHEN THIS CONDITION IS MET HERE
else	{
