Homematic - Actions for HmIP-WRC6 / HM-PB-6-WM55
When a button is pressed, the defined actions will be executed. Please keep in mind, that long-press actions might be executed multiple times, according to your configured minimum duration for long press. This can be configured in your CCU.
Please use your HmIP-WRC6 / HM-PB-6-WM55 Devicename as shown in your CCU.
Requirements:
  • HmIP-WRC6 or HM-PB-6-WM55 Device
  • Homematic Integration for your CCU. Homematic IP Cloud is not supported!
Blueprint:
blueprint:
  name: Actions for HmIP-WRC6
  description: When a button is pressed, the defined actions will be executed. Please keep in mind, that long-press actions might be executed multiple times, according to your configured minimum duration for long press. This can be configured in your CCU.
  domain: automation
  input:
    switch:
        description: Please select a HmIP-WRC6 entity of your Homematic (not Homematic Cloud) integration by typing in the name of the device which was set in your CCU.
    action_left_top_short:
        description: Left-Top-Button, Short Press
        default: []
        selector:
            action: {}
    action_left_top_long:
        description: Left-Top-Button, Long Press
        default: []
        selector:
            action: {}
    action_right_top_short:
        description: Right-Top-Button, Short Press
        default: []
        selector:
            action: {}
    action_right_top_long:
        description: Right-Top-Button, Long Press
        default: []
        selector:
            action: {}
    action_left_middle_short:
        description: Left-Middle-Button, Short Press
        default: []
        selector:
            action: {}
    action_left_middle_long:
        description: Left-Middle-Button, Long Press
        default: []
        selector:
            action: {}
    action_right_middle_short:
        description: Right-Middle-Button, Short Press
        default: []
        selector:
            action: {}
    action_right_middle_long:
        description: Right-Middle-Button, Long Press
        default: []
        selector:
            action: {}
    action_left_bottom_short:
        description: Left-Bottom-Button, Short Press
        default: []
        selector:
            action: {}
    action_left_bottom_long:
        description: Left-Bottom-Button, Long Press
        default: []
        selector:
            action: {}
    action_right_bottom_short:
        description: Right-Bottom-Button, Short Press
        default: []
        selector:
            action: {}
    action_right_bottom_long:
        description: Right-Bottom-Button, Long Press
        default: []
        selector:
            action: {}
  - platform: event
    event_type: homematic.keypress
    event_data:
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: >-
              {{ trigger.event.data.channel == 1 and trigger.event.data.param == 'PRESS_SHORT' }}
        sequence: !input 'action_left_top_short'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 1 and trigger.event.data.param == 'PRESS_LONG' }}
        sequence: !input 'action_left_top_long'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 2 and trigger.event.data.param == 'PRESS_SHORT' }}
        sequence: !input 'action_right_top_short'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 2 and trigger.event.data.param == 'PRESS_LONG' }}
        sequence: !input 'action_right_top_long'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 3 and trigger.event.data.param == 'PRESS_SHORT' }}
        sequence: !input 'action_left_middle_short'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 3 and trigger.event.data.param == 'PRESS_LONG' }}
        sequence: !input 'action_left_middle_long'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 4 and trigger.event.data.param == 'PRESS_SHORT' }}
        sequence: !input 'action_right_middle_short'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 4 and trigger.event.data.param == 'PRESS_LONG' }}
        sequence: !input 'action_right_middle_long'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 5 and trigger.event.data.param == 'PRESS_SHORT' }}
        sequence: !input 'action_left_bottom_short'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 5 and trigger.event.data.param == 'PRESS_LONG' }}
        sequence: !input 'action_left_bottom_long'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 6 and trigger.event.data.param == 'PRESS_SHORT' }}
        sequence: !input 'action_right_bottom_short'
      - conditions:
            value_template: >-
              {{ trigger.event.data.channel == 6 and trigger.event.data.param == 'PRESS_LONG' }}
        sequence: !input 'action_right_bottom_long'
mode: parallel
max: 10
Fantastic job
One remark from my side: I think naming it switch is not correct in english. RemoteControl or PushButton is better.
If you’re interested, you can use Variables and the shorthand notation for Template Conditions to reduce the size of the action section.
  - variables:
      channel: '{{ trigger.event.data.channel }}'
      param: '{{ trigger.event.data.param }}'
  - choose:
      - conditions: "{{ channel == 1 and param == 'PRESS_SHORT' }}"
      - conditions: "{{ channel == 1 and param == 'PRESS_LONG' }}"
      - conditions: "{{ channel == 2 and param == 'PRESS_SHORT' }}"
      - conditions: "{{ channel == 2 and param == 'PRESS_LONG' }}"
      - conditions: "{{ channel == 3 and param == 'PRESS_SHORT' }}"
      - conditions: "{{ channel == 3 and param == 'PRESS_LONG' }}"
      - conditions: "{{ channel == 4 and param == 'PRESS_SHORT' }}"
      - conditions: "{{ channel == 4 and param == 'PRESS_LONG' }}"
      - conditions: "{{ channel == 5 and param == 'PRESS_SHORT' }}"
      - conditions: "{{ channel == 5 and param == 'PRESS_LONG' }}"
      - conditions: "{{ channel == 6 and param == 'PRESS_SHORT' }}"
      - conditions: "{{ channel == 6 and param == 'PRESS_LONG' }}"
If you wish, you can even create variables for short and long as well.
  - variables:
      short: 'PRESS_SHORT'
      long: 'PRESS_LONG'
  - choose:
      - conditions: "{{ channel == 1 and param == short }}"
      - conditions: "{{ channel == 1 and param == long }}"
 ... etc ...
Nice! I modified yours to work with a HmIP-KRC4.
A link to the gist
I just wanted to build a similar thing for HM-PB-6-WM55, and realized that your blueprint is compatible to this one as well. You might want to add that to the title :slight_smile:
Thanks for your work!
Great to hear! I’ll add this to the description.
Is this still working for you… it detects the push from the wrc6 button, but it does not trigger an event in nodered. If I trigger the automation manually, nodered gets triggered. Link homeassistant and nodered seems to be working, likewise ccu homeassistant gets triggered, but somehow things get lost in translation. Did something change in homeassistant that requires the template to be revised?
Resolved by using a different blueprint: custom_homematic/homematicip_local-actions-for-6-button.yaml at 789b37f30e07eefe9edefae6d774590e17f21bf4 · danielperna84/custom_homematic · GitHub
Hi there,
yesterday i tried to implement the HmIP-WRC6 into HA. So i followed the intruction on https://github.com/danielperna84/custom_homematic#events-for-homematicip-devices
So program on CCU/Raspberrymatic created an disabled. In HA ich see the device but it has only two channels. These channels works fine and i can trigger automations with these channels. The other 4 channels are missing. so if i hit the button, nothing happens.Bildschirmfoto 2023-10-02 um 16.38.48
Any ideas?
CYA
worked for me as well
Does anyone know how I can control the LED from the button? Haven’t found anything about this ?
Great work, thanks a lot!
Any idea how to realize an action to be taken only in case of simultaneous pressing of two buttons?
For example:
top-left + top-right simultaneously = script is getting executed
Intention is to avoid any kind of “push by accident” since I’d like to use it to activate our alarming-system; would be terribly loud to activate if a window / door is open that moment… :wink:
In such constellation I may use with not making use of the single buttons any longer…
No, this is not possible as the hardware does not support that.
Too bad but thanks a lot for your reply!
Thanks for this great blueprint. I have one question regarding dimming with long button presses:
I am using both HMIP Cloud and HMIP Raspberrymatic addon with Home Assistant. To be more flexible, I have installed all my wall switches (Taster) on the Raspberrymatic and can now configure their use very flexible with this blueprint!
With one WRC6 I would like to use a button pair to operate a dimming plug (HmIP-PDT). While the short button presses can turn on/off the plug, how do I implement a dimming process, e.g. incrementally dimm the light while holding it pressed? Any ideas?
Thanks a lot!
I’m also looking for a way how to control the LEDs.
Are there any news regarding this topic? Thanks!
Hello Markus
You are pinging a very old post.
Are you asking for changes to a 4 year old Blueprint? I suggest looking at the alternatives listed or taking control of your copy of the blueprint and changing it yourself.
Well, the initial answer regarding the LEDs is just 2 years old :slight_smile:
I didn’t use any blueprint right now, I’m just wondering why there are no entities for the LEDs. :slight_smile:
