Hi folks,
I needt some help. I tried to get Homematic with HM-MOD-RPI-PCB on my RaspberryPi 3B+ with Home Assistant 0.90.2 to run, but failed.
Therefore I checked several forums and the description on https://www.home-assistant.io/addons/homematic/.
My confix.txt looks in the meanwhile like that but I tried all combinations:
dtoverlay=pi3-miniuart-bt
#enable_uart=1
My configuration.yaml lloks like that:
homematic: interfaces: rf: host: core-homematic port: 2001 wired: host: core-homematic port: 2000 hmip: host: core-homematic port: 2010 device_tracker: - platform: bluetooth_tracker interval_seconds: 10 consider_home: 180 new_device_defaults: track_new_devices: false hide_if_away: false
I get the following error logs:
components/device_tracker/bluetooth_tracker.py
OSError: [Errno 19] No such device
components/homematic/init.py
Failed to initialize proxy
