Hi all,
so it turns out I’m slightly too dumb to figure out how to connect my new Homematic CCU3 with HA. Home Assistant 0.82.1 on hass.io on a RPi3, and my various ZigBee/Sonos bits are fine. The CCU3 is running the latest 3.41.11 firmware.
My HA setup runs on 192.168.2.60, and the CCU3 resolves to 192.168.2.137.
My configuration looks like this:
homematic:
interfaces:
ip:
host: 192.168.2.137
port: 2000
resolvenames: json
username: ha
password: xxx
hosts:
ccu3:
host: 192.168.2.137
username: ha
password: xxx
(The password is obviously edited.)
Unfortunately, the HA logs are not quite so enlightening:
2018-11-18 16:55:49 INFO (MainThread) [homeassistant.loader] Loaded homematic from homeassistant.components.homematic
2018-11-18 16:55:49 INFO (MainThread) [homeassistant.setup] Setting up homematic
2018-11-18 16:55:49 INFO (SyncWorker_3) [pyhomematic._hm] Creating proxy ip. Connecting to http://192.168.2.137:2000
2018-11-18 16:55:49 INFO (SyncWorker_3) [pyhomematic._hm] Creating proxy ccu3. Connecting to http://192.168.2.137:2001
2018-11-18 16:55:49 INFO (Thread-2) [pyhomematic._hm] Starting server at http://0.0.0.0:39615
2018-11-18 16:55:49 WARNING (SyncWorker_3) [pyhomematic._hm] Failed to initialize proxy
What I’ve tried:
- Using the “Admin” user on the CCU3 instead of the “ha” guest. No change.
- Checked that the ports on the CCU3 are open - I can connect to the 2001/2010/80/2000 ports on the IP.
- When I connect to via a browser, I do get prompted for credentials and get an empty response.
- I’ve tried using local_ip, local_port, callback_ip to see if maybe it was being confused by the HASS.IO setup (I found those parameters elsewhere), but that didn’t change anything.
- I have a HM-LC-Dim1T-CV connected to the CCU3 which I can control via the CCU3, so there should be at least one light to retrieve, so it’s also not being confused by an empty list.
- That light has also been assigned a shortname.
- Triggering “homematic.reconnect” makes no difference either.
- Tried the other ports (2000, 2001, 2010, 9292) with no change.
I’m a bit at a loss. I’d appreciate help, because I’d love to benefit from the choice of Homematic devices!
Thanks in advance.
