I need some help to getting started with the Homematic Component.
I installed homeassistant on an ubuntu 17.10 machine running on my freenas server. The ubuntu machine is only used for hass an installed according to: Installation on top of python.
I got hass up and running. But not the Homematic Component. It gives me the following message:
“Invalid config The following components and platforms could not be set up:”
“title”: “Invalid config”,
“message”: “The following components and platforms could not be set up:\n\n - homematic\n\nPlease check your config.”
I added the following lines to yaml.config:
homematic:
interfaces:
rf:
host: 192.168.178.22
resolvenames: json
username: Admin
password: MASKED
primary: true
variables: true
As I understood it, that should be enough for a first scan of the homematic devices. But obviously it is not
The check at yamllint tells me I used valid YAML
Do I have to make “something” to install the component? I couln`t find I hint for that. I just added the above lines to the yaml.config.
Perhaps someone can help.
Thanks in advance!
olb
