Based on this great work i modified the code for my needs and now i can control lights etc.with my
HomeMatic Display Switches: HM-PB-4DIS-WM
If someone is looking for this cool switch, please use this:
For sure - any suggestions and feedback are welcome.
Features:
- Short press buttons
- Long press buttons
If you don’t get the homematic.keypress events from the switch but from the CCU-GUI, follow this guide.
blueprint:
name: HomeMatic - HM-PB-4DIS-WM - Display Switch
description: "Automate your HomeMatic Display Switch - HM-PB-4DIS-WM"
domain: automation
input:
hm_name_string:
name: HomeMatic - Display Switch Name
description: "The given name of the Display Switch in HomeMatic CCU"
default: "Display Switch Name in CCU"
channel_01_short_press:
name: Channel 01 (Switch - SHORT_PRESS 01)
description: Action to run when Display Switch is pressed short on Channel 01
default: []
selector:
action: {}
channel_02_short_press:
name: Channel 02 (Switch - SHORT_PRESS 01)
description: Action to run when Display Switch is pressed short on Channel 02
default: []
selector:
action: {}
channel_03_short_press:
name: Channel 03 (Switch - SHORT_PRESS 02)
description: Action to run when Display Switch is pressed short on Channel 03
default: []
selector:
action: {}
channel_04_short_press:
name: Channel 04 (Switch - SHORT_PRESS 02)
description: Action to run when Display Switch is pressed short on Channel 04
default: []
selector:
action: {}
channel_05_short_press:
name: Channel 05 (Switch - SHORT_PRESS 03)
description: Action to run when Display Switch is pressed short on Channel 05
default: []
selector:
action: {}
channel_06_short_press:
name: Channel 06 (Switch - SHORT_PRESS 03)
description: Action to run when Display Switch is pressed short on Channel 06
default: []
selector:
action: {}
channel_07_short_press:
name: Channel 07 (Switch - SHORT_PRESS 04)
description: Action to run when Display Switch is pressed short on Channel 07
default: []
selector:
action: {}
channel_08_short_press:
name: Channel 08 (Switch - SHORT_PRESS 04)
description: Action to run when Display Switch is pressed short on Channel 08
default: []
selector:
action: {}
channel_09_short_press:
name: Channel 09 (Switch - SHORT_PRESS 05)
description: Action to run when Display Switch is pressed short on Channel 09
default: []
selector:
action: {}
channel_10_short_press:
name: Channel 10 (Switch - SHORT_PRESS 05)
description: Action to run when Display Switch is pressed short on Channel 10
default: []
selector:
action: {}
channel_11_short_press:
name: Channel 11 (Switch - SHORT_PRESS 06)
description: Action to run when Display Switch is pressed short on Channel 11
default: []
selector:
action: {}
channel_12_short_press:
name: Channel 12 (Switch - SHORT_PRESS 06)
description: Action to run when Display Switch is pressed short on Channel 12
default: []
selector:
action: {}
channel_13_short_press:
name: Channel 13 (Switch - SHORT_PRESS 07)
description: Action to run when Display Switch is pressed short on Channel 13
default: []
selector:
action: {}
channel_14_short_press:
name: Channel 14 (Switch - SHORT_PRESS 07)
description: Action to run when Display Switch is pressed short on Channel 14
default: []
selector:
action: {}
channel_15_short_press:
name: Channel 15 (Switch - SHORT_PRESS 08)
description: Action to run when Display Switch is pressed short on Channel 15
default: []
selector:
action: {}
channel_16_short_press:
name: Channel 16 (Switch - SHORT_PRESS 08)
description: Action to run when Display Switch is pressed short on Channel 16
default: []
selector:
action: {}
channel_17_short_press:
name: Channel 17 (Switch - SHORT_PRESS 09)
description: Action to run when Display Switch is pressed short on Channel 17
default: []
selector:
action: {}
channel_18_short_press:
name: Channel 18 (Switch - SHORT_PRESS 09)
description: Action to run when Display Switch is pressed short on Channel 18
default: []
selector:
action: {}
channel_19_short_press:
name: Channel 19 (Switch - SHORT_PRESS 10)
description: Action to run when Display Switch is pressed short on Channel 19
default: []
selector:
action: {}
channel_20_short_press:
name: Channel 20 (Switch - SHORT_PRESS 10)
description: Action to run when Display Switch is pressed short on Channel 20
default: []
selector:
action: {}
channel_01_long_press:
name: Channel 01 (Switch - LONG_PRESS 01)
description: Action to run when Display Switch is pressed long on Channel 01
default: []
selector:
action: {}
channel_02_long_press:
name: Channel 02 (Switch - LONG_PRESS 01)
description: Action to run when Display Switch is pressed long on Channel 02
default: []
selector:
action: {}
channel_03_long_press:
name: Channel 03 (Switch - LONG_PRESS 02)
description: Action to run when Display Switch is pressed long on Channel 03
default: []
selector:
action: {}
channel_04_long_press:
name: Channel 04 (Switch - LONG_PRESS 02)
description: Action to run when Display Switch is pressed long on Channel 04
default: []
selector:
action: {}
channel_05_long_press:
name: Channel 05 (Switch - LONG_PRESS 03)
description: Action to run when Display Switch is pressed long on Channel 05
default: []
selector:
action: {}
channel_06_long_press:
name: Channel 06 (Switch - LONG_PRESS 03)
description: Action to run when Display Switch is pressed long on Channel 06
default: []
selector:
action: {}
channel_07_long_press:
name: Channel 07 (Switch - LONG_PRESS 04)
description: Action to run when Display Switch is pressed long on Channel 07
default: []
selector:
action: {}
channel_08_long_press:
name: Channel 08 (Switch - LONG_PRESS 04)
description: Action to run when Display Switch is pressed long on Channel 08
default: []
selector:
action: {}
channel_09_long_press:
name: Channel 09 (Switch - LONG_PRESS 05)
description: Action to run when Display Switch is pressed long on Channel 09
default: []
selector:
action: {}
channel_10_long_press:
name: Channel 10 (Switch - LONG_PRESS 05)
description: Action to run when Display Switch is pressed long on Channel 10
default: []
selector:
action: {}
channel_11_long_press:
name: Channel 11 (Switch - LONG_PRESS 06)
description: Action to run when Display Switch is pressed long on Channel 11
default: []
selector:
action: {}
channel_12_long_press:
name: Channel 12 (Switch - LONG_PRESS 06)
description: Action to run when Display Switch is pressed long on Channel 12
default: []
selector:
action: {}
channel_13_long_press:
name: Channel 13 (Switch - LONG_PRESS 07)
description: Action to run when Display Switch is pressed long on Channel 13
default: []
selector:
action: {}
channel_14_long_press:
name: Channel 14 (Switch - LONG_PRESS 07)
description: Action to run when Display Switch is pressed long on Channel 14
default: []
selector:
action: {}
channel_15_long_press:
name: Channel 15 (Switch - LONG_PRESS 08)
description: Action to run when Display Switch is pressed long on Channel 15
default: []
selector:
action: {}
channel_16_long_press:
name: Channel 16 (Switch - LONG_PRESS 08)
description: Action to run when Display Switch is pressed long on Channel 16
default: []
selector:
action: {}
channel_17_long_press:
name: Channel 17 (Switch - LONG_PRESS 09)
description: Action to run when Display Switch is pressed long on Channel 17
default: []
selector:
action: {}
channel_18_long_press:
name: Channel 18 (Switch - LONG_PRESS 09)
description: Action to run when Display Switch is pressed long on Channel 18
default: []
selector:
action: {}
channel_19_long_press:
name: Channel 19 (Switch - LONG_PRESS 10)
description: Action to run when Display Switch is pressed long on Channel 19
default: []
selector:
action: {}
channel_20_long_press:
name: Channel 20 (Switch - LONG_PRESS 10)
description: Action to run when Display Switch is pressed long on Channel 20
default: []
selector:
action: {}
source_url: https://dummyurl.com/new
mode: restart
max_exceeded: silent
- platform: event
event_type: homematic.keypress
event_data:
name: !input hm_name_string
condition: []
# - variables:
# command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- condition: template
value_template: >-
{{ trigger.event.data.channel == 1 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_01_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 2 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_02_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 3 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_03_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 4 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_04_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 5 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_05_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 6 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_06_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 7 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_07_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 8 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_08_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 9 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_09_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 10 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_10_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 11 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_11_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 12 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_12_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 13 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_13_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 14 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_14_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 15 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_15_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 16 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_16_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 17 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_17_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 18 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_18_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 19 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_19_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 20 and trigger.event.data.param == 'PRESS_SHORT' }}
sequence: !input 'channel_20_short_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 1 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_01_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 2 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_02_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 3 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_03_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 4 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_04_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 5 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_05_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 6 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_06_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 7 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_07_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 8 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_08_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 9 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_09_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 10 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_10_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 11 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_11_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 12 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_12_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 13 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_13_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 14 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_14_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 15 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_15_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 16 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_16_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 17 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_17_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 18 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_18_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 19 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_19_long_press'
- conditions:
value_template: >-
{{ trigger.event.data.channel == 20 and trigger.event.data.param == 'PRESS_LONG' }}
sequence: !input 'channel_20_long_press'
