Hi folks,
I’m using hass.io since 0.7x or maybe earlier and updated the same image up to the current version 0.102.3
I’m using it with several hardware addons like Zigbee or Zwave (both USB) and one Raspberry PI Hat for Homematic (not IP!) on a Raspberry 2 and 3 and everything is working like a charme.
But now I wanted to switch to a new SD card due to capacity problems but it failed because the new hass.io Image seems to cause problems.
I downloaded the latest hass.io Image and flashed with Etcher, took a snapshot from my existing installation and after restore everything except Homematic works on the same Raspberry.
If I take a copy of the old SD card with “dd” and write it to a new card and restore the same snapshot all works even Homematic.
What I now is that the Linux from the image has changed to speed up hass.io (which is really working) but may this change is causing trouble? Does anybody use the new image with the Homematic (not IP!) hat successfully on a Raspberry without any trouble?
I tried it already several times in various setups even with another Pi but none worked until now.
Thank you very much for any reply.
Regards
Joris
