I’ve one HM-LC-Dim2T-SM which is a dimmer switch with two separate channels.
The switch/light shows up in HA but only the first channel.
the api output from the CCU shows both channels
Your device probably only has been implemented by specification, not by actually testing it (since no one had it in use so far). You can open an issue about that here: https://github.com/danielperna84/pyhomematic
