I want to use event data from my HM-MOD-EM-8 to trigger automations, when opening/closing circuit. For this I could use the switch or sensor-setting in CCU3, but these settings don’t generate a homematic event
This is the log entry with switch-setting:
2021-03-31 15:43:36 DEBUG (Thread-3) [pyhomematic._hm] RPCFunctions.event: interface_id = homeassistant-rf, address = PEQ0106163:7, value_key = PRESS, value = True
2021-03-31 15:43:36 INFO (Thread-3) [pyhomematic.devicetypes.generic] HMGeneric.event: address=PEQ0106163:7, interface_id=homeassistant-rf, key=PRESS, value=True
2021-03-31 15:43:36 DEBUG (Thread-3) [pyhomematic.devicetypes.generic] HMGeneric.event: Using callback functools.partial(<function _hm_event_handler at 0x7f0547b1f670>, <homeassistant.core.HomeAssistant object at 0x7f0551bb57f0>, 'rf')
This is the log entry with sensor-setting:
2021-03-31 15:44:13 DEBUG (Thread-3) [pyhomematic._hm] RPCFunctions.event: interface_id = homeassistant-rf, address = PEQ0106163:7, value_key = STATE, value = True
2021-03-31 15:44:13 INFO (Thread-3) [pyhomematic.devicetypes.generic] HMGeneric.event: address=PEQ0106163:7, interface_id=homeassistant-rf, key=STATE, value=True
2021-03-31 15:44:13 DEBUG (Thread-3) [pyhomematic.devicetypes.generic] HMGeneric.event: Using callback functools.partial(<function _hm_event_handler at 0x7f0547b1f670>, <homeassistant.core.HomeAssistant object at 0x7f0551bb57f0>, 'rf')
The Homematic integration detects the state changes, but no homematic event which I can use to trigger an automation is generated.
However, when using button-setting I get an different output:
2021-03-31 15:43:25 DEBUG (Thread-3) [pyhomematic._hm] RPCFunctions.event: interface_id = homeassistant-rf, address = PEQ0106163:7, value_key = PRESS_LONG, value = True
2021-03-31 15:43:25 INFO (Thread-3) [pyhomematic.devicetypes.generic] HMGeneric.event: address=PEQ0106163:7, interface_id=homeassistant-rf, key=PRESS_LONG, value=True
2021-03-31 15:43:25 DEBUG (Thread-3) [pyhomematic.devicetypes.generic] HMGeneric.event: Using callback functools.partial(<function _hm_event_handler at 0x7f0547b1f670>, <homeassistant.core.HomeAssistant object at 0x7f0551bb57f0>, 'rf')
2021-03-31 15:43:25 DEBUG (Thread-3) [homeassistant.components.homematic] Event PRESS_LONG for LF_input channel 7
I can then use this to trigger an automation:
- platform: event
event_type: homematic.keypress
event_data:
channel: 7
param: PRESS_LONG
But I can’t use the button setting for my physical application (detection open/closed state). Can I get the integration to generate a homematic event to trigger automations in switch or sensor-mode?
Or are there a way to trigger automations from the pyhomematic HMGeneric event?
