Since I’ve run through the updates of the two latest versions my Homematic lock (HM-SEC-Key) is not working anymore. I mentioned that my automation, to lock the door at night, had no effect on the lock at my door.
The lock is paired successful with homegear and is shown in the homematic config tool. What I tried is to unpair and reset the lock and start from skretch.
After the re-pairing of the device, it is shown in homeassistant as switch (like it was before), but it doesn’t respond on any command (on/off).
I allowed the needed changes in pyhomematic believing that it won’t take the developers long to get the HA side done. Unfortunately this has somehow stalled. If none of the two PRs get merged prior to the next release I will revert the relevant changes in pyhomematic to restore the previously working funktionality.
I don’t know about that. I have never used the emulated hue. If it supports locks, then yes. If not, then you would probably wrap the lock with some template switch that makes use of the lock entity.
