Homematic HmIP-MOD-OC8 not showing up in Home Assistant
EDIT:
Just realized that HmIP-MOD-OC8 support was added in version 0.106.2 I was running 0.105.4
Sorry for confusion and, @danielperna84, thanks for your fantastic work! :slight_smile:
Damos
Hi everyone,
Until today, every device I’ve installed so far in Homematic, showed up almost immediately in Home Assistant.
Yesterday I installed the HmIP-MOD-OC8 device in Homematic, but Home Assistant did not detect it. Based on the device list provided here danielperna84 / pyhomematic, it is supported.
Any idea? Thanks!
PS: I’m running
  Homematic v3.47.15
  XML-API v1.20
  Home Assistant Core 0.105.4
Here’s the particular part from my configuration.yaml:
homematic:
  interfaces:
    wireless:
      host: !secret ccu3_ip_address
      username: !secret ccu3_username
      password: !secret ccu3_password
    rf:
      resolvenames: json
    wired:
      port: 2000
      resolvenames: json
    ip:
      port: 2010
    groups:
      port: 9292
      resolvenames: json
      path: /groups
  hosts:
    ccu3:
I got two HmIP-MOD-OC8, both do not show up. Any clues?
Thanks. Cu!
@Damos, how do they show up in home assistant for you?
Unfortunately, I do not have them integrated anymore because I’m moving them to a different building.
However, as far as I remember, I could integrate every single switch.
Well. Found the cause. Somehow the ended up in “disabled”. They are avail and working.
