Homematic HmIP-RCV-50 not working with virtual key any more
Hi everybody,
since the august update 3.53.26 of my CCU3 (now on 3.53.34, HA on 0.118.2) I can’t trigger the buttons of the HmIP-RCV-50 anymore.
E. g. when I call the following script, nothing happens:
l_eg_wohnbereich_aus:
  sequence:
    - service: homematic.virtualkey
        address: HmIP-RCV-50
        channel: 20
        param: PRESS_SHORT
But there is a log entry in the logs stating:
2020-11-25 19:48:03 ERROR (SyncWorker_2) [homeassistant.components.homematic] HMIP-RCV-50 not found for service virtualkey!
Unfortunately, that all worked before the update.
When I go to the ccu, I’m able to press any button on the HmIP-RCV-50 without problems.
I heard of that update renaming the HmIP-RCV-50. But in the ccu I can execute the following script successfully:
object obj = devices.Get("HmIP-RCV-50");
if(obj) {
  WriteLine("found");
else {
  WriteLine("not found");
It states, that the device is found by name.
Perhaps I’m missing something out or someone else was in a similar situation and found a solution. So it would be great, if anyone could help me.
Best,
Jan
Hi!
I’m experiencing exactly the same Problem. I tried to invoke a virtual button on the CCU with different adresses. Pushing the button on the Homematic interface works fine. Also does invoking a BidCos-RD virtual key via Home Assistant. When I switch to HmIP, nothing happens.
Service homematic.virtualkey with params:
address: HmIP-RCV-1
channel: 11
param: PRESS_LONG
interface: HMIP
“HMIP” is the interface name from my configuration.yaml.
From the Home Assistant Log:
Logger: homeassistant.components.homematic
Source: components/homematic/init.py:273
Integration: Homematic (documentation, issues)
First occurred: 20:57:41 (11 occurrences)
Last logged: 21:05:38
  • HMIP-RCV-1 not found for service virtualkey!
  • ZENTRALE HMIP not found for service virtualkey!
  • HMIP-RCV-50 not found for service virtualkey!
  • HMIP-RF not found for service virtualkey!
From the Homematic Device list:
Typenbezeichnung: HmIP-RCV-50
Seriennummer: HmIP-RCV-1
Running the test script only works with the CCU name, not its identifier:
object obj = devices.Get("Zentrale HmIP");
if(obj) {
  WriteLine("found");
else {
It would be great if someone could help.
Best regards
Björn
did some of you solve the problem? I have the same issue.
Thanks and best regards
Florian
Nothing has changed in pyhomematic regarding the CCU. It’s still defined as a remote here. So it probably is cause by an update of the CCU.
I also think, it has something to do with the CCU update, as it was working flawlessly before 3.53.26.
Today I installed the 3.55.10 update. But still I can’t reach the buttons. Perhaps one could help me where to start debugging?
I tried the same thing (using virtualkey hmip-rcv-1 to address hmip-wgc).
but still got the same message in the homeassistant log:
HMIP-WGC not found for service virtualkey!
has someone already solved this issue or is it really related to the CCU version?
i would really appreciate some good news on this topic :slight_smile:
Seems like to be a case-sensitivity problem as described in
I was able to make it work (via custom component) and created a pull-request with the fix
