I am about to switch my home assistant installation from an ESXI VM to a dedicated hardware box.
My current installation in a VM has a Conbee 2 stick and a Homematic HMIP RF-USB stick connected successfully.
This new box is a Gigabyte J4105N-H Mainboard with Intel Celeron J4105 Quad-Core CPU and 8 GB of ram. I first tried to install the HassOS NUC image by dd the image to the internal SSD using a live CD. But unfortunately it threw a lot of errors when booting and never loaded the WebUI.
So I switched to Home Assistant Supervised on Debian 10 64bit which installed just fine and also detected the Zigbee Conbee 2 stick. But the Homematic stick is not being detected by Home Assistant. Means it doesn’t show up under Hardware nor does the Homematic Add-on start because of this.
In Debian the Homematic stick seems to be detected without errors:
ha@user01:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:c30e Logitech, Inc. UltraX Keyboard (Y-BL49)
Bus 001 Device 003: ID 1b1f:c020 eQ-3 Entwicklung GmbH
Bus 001 Device 002: ID 1cf1:0030 Dresden Elektronik
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ha@user1:~$ dmesg | grep usb
[ 2.481468] usbcore: registered new interface driver usbfs
[ 2.481477] usbcore: registered new interface driver hub
[ 2.481513] usbcore: registered new device driver usb
[ 2.500921] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 2.500922] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.500924] usb usb1: Product: xHCI Host Controller
[ 2.500925] usb usb1: Manufacturer: Linux 4.19.0-10-amd64 xhci-hcd
[ 2.500926] usb usb1: SerialNumber: 0000:00:15.0
[ 2.502460] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.502461] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.502462] usb usb2: Product: xHCI Host Controller
[ 2.502463] usb usb2: Manufacturer: Linux 4.19.0-10-amd64 xhci-hcd
[ 2.502464] usb usb2: SerialNumber: 0000:00:15.0
[ 2.838492] usb 1-5: new full-speed USB device number 2 using xhci_hcd
[ 2.988380] usb 1-5: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[ 2.988387] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.988390] usb 1-5: Product: ConBee II
[ 2.988394] usb 1-5: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[ 2.988397] usb 1-5: SerialNumber: DE2190225
[ 3.118254] usb 1-6: new full-speed USB device number 3 using xhci_hcd
[ 3.267849] usb 1-6: New USB device found, idVendor=1b1f, idProduct=c020, bcdDevice= 1.00
[ 3.267852] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.267853] usb 1-6: Product: eQ-3 HmIP-RFUSB
[ 3.267854] usb 1-6: Manufacturer: Silicon Labs
[ 3.267856] usb 1-6: SerialNumber: 3014F711A061A7C00010CECF
[ 3.394352] usb 1-8: new low-speed USB device number 4 using xhci_hcd
[ 3.571903] usb 1-8: New USB device found, idVendor=046d, idProduct=c30e, bcdDevice= 1.80
[ 3.571905] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.571906] usb 1-8: Product: HID compliant keyboard
[ 3.571907] usb 1-8: Manufacturer: Logitech
[ 3.909965] usbcore: registered new interface driver cdc_acm
[ 4.044447] usbcore: registered new interface driver usbhid
[ 4.044449] usbhid: USB HID core driver
[ 4.123079] input: Logitech HID compliant keyboard as /devices/pci0000:00/0000:00:15.0/usb1/1-8/1-8:1.0/0003:046D:C30E.0001/input/input2
[ 4.182429] hid-generic 0003:046D:C30E.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech HID compliant keyboard] on usb-0000:00:15.0-8/input0
[ 4.182618] input: Logitech HID compliant keyboard Consumer Control as /devices/pci0000:00/0000:00:15.0/usb1/1-8/1-8:1.1/0003:046D:C30E.0002/input/input4
[ 4.242446] input: Logitech HID compliant keyboard System Control as /devices/pci0000:00/0000:00:15.0/usb1/1-8/1-8:1.1/0003:046D:C30E.0002/input/input5
[ 4.242824] hid-generic 0003:046D:C30E.0002: input,hidraw1: USB HID v1.10 Device [Logitech HID compliant keyboard] on usb-0000:00:15.0-8/input1
But there is no “by-id” being generated:
ha@user1:~$ ls /dev/serial/by-id/ -al
total 0
drwxr-xr-x 2 root root 60 Aug 31 13:20 .
drwxr-xr-x 4 root root 80 Aug 31 13:20 ..
lrwxrwxrwx 1 root root 13 Aug 31 13:20 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2190225-if00 -> ../../ttyACM0
The only error message in Home Assistant is:
Failed to initialize proxy for homeassistant-hmip
But I guess that’s just the result of the homematic stick not being available in HA.
Has anyone an idea what the issue could be or point me into the right direction for further troubleshooting?
thx and Best
Pete
