Homematic (HMIP-RFUSB): no devices found after switch to RaspberryMatic
Hi there,
I recently switched from HomeMatic CCU add-on to RaspberryMatic following the official guide.
Now Homematic does not work anymore. I tried to restore the sbk-backup file. Despite message “System backup has been imported successfully” the device list stays empty after restart. The hardware (HMIP-RFUSB) worked fine all the time, so I am rather certain that its a software issue.
The log shows following error which might be related:
Updating Homematic RF-Hardware: HMIP-RFUSB: =>4.4.16, ERROR ( != 4.4.16)
Here is the full log:
Mounting /data as /usr/local (Home Assistant Add-On): OK
Starting watchdog...
Identifying onboard hardware: oci, OK
Initializing RTC Clock: no hardware found
Running sysctl: OK
Checking for Factory Reset: not required
Checking for Backup Restore: not required
Initializing System: OK
Starting logging: OK
Init onboard LEDs: init, OK
Starting irqbalance: OK
Starting iptables: OK
Starting network: eth0: link up, fixed, firewall, inet up, 172.30.33.4, OK
Identifying Homematic RF-Hardware: ...HmRF: none, HmIP: none, OK
Starting hs485dLoader: disabled
Starting xinetd: OK
Starting eq3configd: OK
Starting lighttpd: OK
Starting ser2net: disabled
Starting ssdpd: OK
Starting ha-proxy: OK
Starting NUT services: disabled
Initializing Third-Party Addons: OK
Starting LGWFirmwareUpdate: ...OK
Setting LAN Gateway keys: OK
Starting hs485d: disabled
Starting multimacd: not required
Starting rfd: no BidCos-RF hardware found
Starting HMIPServer: .........OK
Starting ReGaHss: .OK
Starting CloudMatic: OK
Starting NeoServer: disabled
Starting Third-Party Addons: OK
Starting crond: OK
Setup onboard LEDs: booted, OK
P.S. : I tried to use a backup to restore the previous HA state but it seems a “full” HA backup is not enough since it does not cover the OS and also not the add-ons from the store. So I didn’t get the old Homematic CCU add-on back nor the old device (its still /dev/raw-art).
Hope someone can help.
I think you will receive better support in the RaspberryMatic section of the HomeMatic Forum. I believe there was someone with a similar problem over there.
Ok, will check it out. Thanks for the hint.
After reading https://github.com/jens-maus/RaspberryMatic/issues/1707, I tried with the nighty build aka “RaspberryMatic (snapshot)” version (3.61.7.20220212-be487fa). With this, I could import my backup and got all my devices back.
Instead of
the log now says:
Identifying Homematic RF-Hardware: ....HmRF: HMIP-RFUSB/eQ-3 [email protected], HmIP: HMIP-RFUSB/eQ-3 [email protected], OK
Updating Homematic RF-Hardware: HMIP-RFUSB: 4.4.16, not necessary, OK
One big step further! :slight_smile:
However, HA could not get any devices from RaspberryMatic:
Here is the log with debug output enabled and my YAML config.
Any ideas?
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic.connection] HMConnection: Creating server object
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] ServerThread.__init__
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] createProxies: Creating proxies
2022-02-13 23:26:14 INFO (SyncWorker_0) [pyhomematic._hm] Creating proxy rf. Connecting to de838cd8-raspberrymatic-dev:2001
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] LockingServerProxy.__init__: Getting local ip
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] LockingServerProxy.__init__: Got local ip 172.30.32.1
2022-02-13 23:26:14 INFO (SyncWorker_0) [pyhomematic._hm] Creating proxy wired. Connecting to de838cd8-raspberrymatic-dev:2000
2022-02-13 23:26:14 INFO (SyncWorker_0) [pyhomematic._hm] Creating proxy hmip. Connecting to de838cd8-raspberrymatic-dev:2010
2022-02-13 23:26:14 INFO (SyncWorker_0) [pyhomematic._hm] Creating proxy groups. Connecting to de838cd8-raspberrymatic-dev:9292/groups
2022-02-13 23:26:14 INFO (SyncWorker_0) [pyhomematic._hm] Creating proxy raspberrymatic. Connecting to de838cd8-raspberrymatic-dev:2001
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] RPCFunctions.__init__
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] RPCFunctions.__init__: iterating proxy = homeassistant-rf
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] RPCFunctions.__init__: iterating proxy = homeassistant-wired
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] RPCFunctions.__init__: iterating proxy = homeassistant-hmip
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] RPCFunctions.__init__: iterating proxy = homeassistant-groups
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] RPCFunctions.__init__: iterating proxy = homeassistant-raspberrymatic
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] ServerThread.__init__: Setting up server
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] ServerThread.__init__: Registering RPC functions
2022-02-13 23:26:14 INFO (Thread-3) [pyhomematic._hm] Starting server at http://10.0.10.8:43359
2022-02-13 23:26:14 DEBUG (SyncWorker_0) [pyhomematic._hm] ServerThread.proxyInit: init('http://172.30.32.1:43359', 'homeassistant-rf')
2022-02-13 23:26:15 DEBUG (SyncWorker_0) [pyhomematic._hm] proxyInit: Exception: [Errno 111] Connection refused
2022-02-13 23:26:15 WARNING (SyncWorker_0) [pyhomematic._hm] Failed to initialize proxy for homeassistant-rf
2022-02-13 23:26:15 DEBUG (SyncWorker_0) [pyhomematic._hm] ServerThread.proxyInit: init('http://172.30.32.1:43359', 'homeassistant-wired')
2022-02-13 23:26:16 DEBUG (SyncWorker_0) [pyhomematic._hm] proxyInit: Exception: [Errno 111] Connection refused
2022-02-13 23:26:16 WARNING (SyncWorker_0) [pyhomematic._hm] Failed to initialize proxy for homeassistant-wired
2022-02-13 23:26:16 DEBUG (SyncWorker_0) [pyhomematic._hm] ServerThread.proxyInit: init('http://172.30.32.1:43359', 'homeassistant-hmip')
2022-02-13 23:26:17 DEBUG (SyncWorker_0) [pyhomematic._hm] proxyInit: Exception: [Errno 111] Connection refused
2022-02-13 23:26:17 WARNING (SyncWorker_0) [pyhomematic._hm] Failed to initialize proxy for homeassistant-hmip
2022-02-13 23:26:17 DEBUG (SyncWorker_0) [pyhomematic._hm] ServerThread.proxyInit: init('http://172.30.32.1:43359', 'homeassistant-groups')
2022-02-13 23:26:18 DEBUG (SyncWorker_0) [pyhomematic._hm] proxyInit: Exception: [Errno 111] Connection refused
2022-02-13 23:26:18 WARNING (SyncWorker_0) [pyhomematic._hm] Failed to initialize proxy for homeassistant-groups
2022-02-13 23:26:18 INFO (SyncWorker_0) [pyhomematic._hm] Skipping init for homeassistant-raspberrymatic
2022-02-13 23:26:20 DEBUG (SyncWorker_6) [pyhomematic._hm] ServerThread.getAllSystemVariables: Getting all System variables via JSON-RPC
2022-02-13 23:26:20 DEBUG (SyncWorker_6) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Method: Session.login
2022-02-13 23:26:20 DEBUG (SyncWorker_6) [pyhomematic._hm] RPCFunctions.jsonRpcPost: API-Endpoint: http://de838cd8-raspberrymatic-dev:80/api/homematic.cgi
  local_ip: 10.0.10.8
  interfaces:
    rf:
      host: de838cd8-raspberrymatic-dev
      port: 2001
      resolvenames: json
      username: Admin
      password: xxx
    wired:
      port: 2000
      resolvenames: json
      username: Admin
      password: xxx
    hmip:
      port: 2010
      resolvenames: json
      username: Admin
      password: xxx
    groups:
      port: 9292
      resolvenames: json
      username: Admin
      password: xxx
      path: /groups
  hosts:
    raspberrymatic:
      username: Admin
      password: xxx
The Connection refused errors indicate, that there is some sort of connectivity issue. Either network or firewall. I don’t know how it is with the RaspberryMatic Add-On out of the box, but I know RaspberryMatic itself has a firewall, and there you have to allow access from Home Assistant. That’s also mentioned in the Docs.
Thanks again for pointing me to the right direction. Despite choosing “Relaxed” security setting in the install wizard of RaspberryMatic, the firewall blocked all access (ports and XML-RPC API)
After opening it, HA could find the devices… :slight_smile: :+1:
