Sorry, my English is very bad, but I hope it’s okay for my simple questions.
I have a RaspberryMatic version 3.57.4 and a Home Assistant OS version 2021.4.3 on two RPI 3 b+. Normally both Raspberry Pi run with SSL, but the Homematic integration doesn’t work with SSL.
This is my configuration with disabled SSL on both RPI:
homematic:
interfaces:
ip:
host: 192.168.178.72
port: 2010
resolvenames: json
username: !secret hm_user
password: !secret hm_pass
rf:
port: 2001
resolvenames: json
groups:
port: 9292
resolvenames: json
path: /groups
hosts:
ccu3:
The result is the connection to a HomeMatic IP thermostat:
hvac_modes:
- auto
- heat
- 'off'
min_temp: 4.5
max_temp: 30.5
target_temp_step: 0.5
preset_modes:
- boost
current_temperature: 22.8
temperature: 22
preset_mode: none
interface: ip
battery: High
rssi_device: -34
valve: 4
level: 0.37
mode: null
voltage: 2.7
friendly_name: Heizung Spitzboden
supported_features: 17
When I activate SSL I have the following errors:
2021-04-11 19:46:43 DEBUG (Thread-3) [pyhomematic._hm] RPCFunctions.addDeviceNames
2021-04-11 19:46:43 DEBUG (Thread-3) [pyhomematic._hm] RPCFunctions.addDeviceNames: Getting names via JSON-RPC
2021-04-11 19:46:43 DEBUG (Thread-3) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Method: Session.login
2021-04-11 19:46:43 DEBUG (Thread-3) [pyhomematic._hm] RPCFunctions.jsonRpcPost: API-Endpoint: http://192.168.178.72:80/api/homematic.cgi
2021-04-11 19:46:43 ERROR (Thread-3) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: <urlopen error [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1125)>
I have my own root CA in my network. Both RPIs have a correct certificate.
subject=C = DE, ST = NRW, O = Private, CN = homematic
issuer=C = DE, ST = NRW, O = Private, CN = fritz.box
X509v3 Subject Alternative Name:
DNS:homematic, DNS:homematic.fritz.box, DNS:192.168.178.72
subject=C = DE, ST = NRW, O = Private, CN = homeassistant
DNS:homeassistant, DNS:homeassistant.fritz.box, DNS:192.168.178.20
I don’t understand this issue. What can be the problem?
