I recently switched from my Homematic IP AccessPoint to debmatic together with the homematic integration in HA. I tried the “Homematic CCU” Addon also, but for some reason i can’t figured out, it does not work in my setup. So I tried the debmatic solution.
My setup is:
- running HA supervised on Raspbian (RPi4) via Docker
- Debmatic running on same RPi.
- HMIP-RFUSB connected to RPi USB Port.
- Reconfigured Debmatic Webserver to run on port 2080 (instead of 80, because that is already in use)
So, everything is working good so far. I can controll any of my HmIP devices without any issues.
The only thing is, that I get these two messages every 30 Seconds in my log:
2020-10-17 07:16:39 ERROR (SyncWorker_51) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 405: Method Not Allowed
2020-10-17 07:16:39 WARNING (SyncWorker_51) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
I can’t figure out where they comming from or what this means in detail. And obviously not able to fix it.
My Homematic related part of configuration.yaml looks like this:
homematic:
interfaces:
ip:
host: !secret ccu_ip
port: 2010
hosts:
ccu2:
port: 2001
username: !secret ccu_user
password: !secret ccu_password
Any help or hint is appreciated!
